Phone Line issue. Not sure what's causing the issue that appeared a few days ago.
- Phone Line issue. Not sure what's causing the issu...
- « Previous
- Next »
Re: Phone Line issue. Not sure what's causing the issue that appeared a few days ago.
27-05-2016 12:03 AM
Ah, that does not help. Well best of luck with it then.
27-05-2016 9:09 AM
What is the router stats sample interval please?
27-05-2016 5:40 PM
Something seems to have happened when I was asleep. The line seems to have gone back to normal at the moment with no noise. Someone mentioned to me that there was a tiny bit of crackling this morning but that was before two BT Vans were at the exchange doing something during this morning/afternoon.
I haven't opened the fault ticket up again unless I see noise fluctuations again today or in the morning. I don't want to have another Enginner mess around with the line if it's possibly been fixed.
@Townman 8 sec/500 points per page
28-05-2016 8:45 AM - edited 28-05-2016 9:18 AM
At 8 seconds 900 points per page or 10 seconds 720 points per page both giving a nice round 2hrs per graph would be best. As you think it's fixed, can you post a daytime SNRM graph please.
Edit: Getting a line with intermittent problems fixed is a trial at the best of times. Getting a line fault fixed on just a broadband fault is fraught with difficulty. You need to take every opportunity to raise or restart a line fault at the slightest sound of noise, as do your neighbours at the same time. Several faults reported at the same time is far more likely to get Openreach to investigate and fix the problem properly, not just test your line and say it's fine just because the test at that instant didn't see a fault.
And don't assume that just because you see Openreach vans at the exchange that they are looking at a fault you had, they could be on a completely different job.
28-05-2016 12:40 PM
ADSL Uptime: 0 days 16 hours 43 minutes 8 seconds
Modulation : G.Dmt
Annex Mode : Annex A/L
Line State : up
Lan Tx : 21675179
Lan Rx : 12514155
ADSL Tx : 1754435
ADSL Rx : 23955720
CRC Down : 0
CRC Up : 78
FEC Down : 3
FEC Up : 52422
HEC Down : 334
HEC Up : 0
SNR Up : 21.0
SNR Down : 3.5
Line Attenuation Up : 16.0
Line Attenuation Down : 37.5
Data Rate Up : 448
Data Rate Down : 7456
28-05-2016 9:40 PM
Can you post a RouterStats daytime SNRM graph?
28-05-2016 11:20 PM - edited 28-05-2016 11:26 PM
The first graph has been consistant with the noise of 3-4dB which went from 12:00 to 20:14. The second graph is where there was a disconnect with the noise reaching minus 1dB and six minutes later returning to 3-4dB.
May 28 20:20:47 pppd[351]: Serial link appears to be disconnected.
May 28 20:20:50 WAN Connection: Fail to connect with some issues.
May 28 20:20:50 stop_nat_rules: apply the redirect_rules!
May 28 20:20:51 WAN Connection: Ethernet link down.
May 28 20:20:53 pppd[351]: Connection terminated.
May 28 20:20:53 pppd[351]: Modem hangup
May 28 20:21:03 pppd[351]: Connected to 00:aa:bb:01:23:45 via interface eth2.1.1
May 28 20:21:03 pppd[351]: Connect: ppp0 <--> eth2.1.1
May 28 20:21:33 pppd[351]: LCP: timeout sending Config-Requests
May 28 20:21:33 pppd[351]: Connection terminated.
May 28 20:21:33 pppd[351]: Modem hangup
May 28 20:21:43 pppd[351]: Connected to 00:aa:bb:01:23:45 via interface eth2.1.1
May 28 20:21:43 pppd[351]: Connect: ppp0 <--> eth2.1.1
May 28 20:22:13 pppd[351]: LCP: timeout sending Config-Requests
May 28 20:22:13 pppd[351]: Connection terminated.
May 28 20:22:13 pppd[351]: Modem hangup
May 28 20:22:23 pppd[351]: Connected to 00:aa:bb:01:23:45 via interface eth2.1.1
May 28 20:22:23 pppd[351]: Connect: ppp0 <--> eth2.1.1
May 28 20:22:53 pppd[351]: LCP: timeout sending Config-Requests
May 28 20:22:53 pppd[351]: Connection terminated.
May 28 20:22:53 pppd[351]: Modem hangup
May 28 20:23:03 pppd[351]: Connected to 00:aa:bb:01:23:45 via interface eth2.1.1
May 28 20:23:03 pppd[351]: Connect: ppp0 <--> eth2.1.1
May 28 20:23:33 pppd[351]: LCP: timeout sending Config-Requests
May 28 20:23:33 pppd[351]: Connection terminated.
May 28 20:23:33 pppd[351]: Modem hangup
May 28 20:23:43 pppd[351]: Connected to 00:aa:bb:01:23:45 via interface eth2.1.1
May 28 20:23:43 pppd[351]: Connect: ppp0 <--> eth2.1.1
May 28 20:24:13 pppd[351]: LCP: timeout sending Config-Requests
May 28 20:24:13 pppd[351]: Connection terminated.
May 28 20:24:13 pppd[351]: Modem hangup
May 28 20:24:23 pppd[351]: Connected to 00:aa:bb:01:23:45 via interface eth2.1.1
May 28 20:24:23 pppd[351]: Connect: ppp0 <--> eth2.1.1
May 28 20:24:53 pppd[351]: LCP: timeout sending Config-Requests
May 28 20:24:53 pppd[351]: Connection terminated.
May 28 20:24:53 pppd[351]: Modem hangup
May 28 20:25:03 pppd[351]: Connected to 00:aa:bb:01:23:45 via interface eth2.1.1
May 28 20:25:03 pppd[351]: Connect: ppp0 <--> eth2.1.1
May 28 20:25:07 pppd[351]: CHAP authentication succeeded
May 28 20:25:07 pppd[351]: peer from calling number 00:AA:BB:01:23:45 authorized
May 28 20:25:08 pppd[351]: local IP address -------
May 28 20:25:08 pppd[351]: remote IP address -----
May 28 20:25:08 pppd[351]: primary DNS address -----
May 28 20:25:08 pppd[351]: secondary DNS address ----
May 28 20:25:08 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
May 28 20:25:08 rc_service: ip-up 715:notify_rc stop_upnp
May 28 20:25:08 miniupnpd[443]: received signal 15, good-bye
May 28 20:25:08 rc_service: ip-up 715:notify_rc start_upnp
May 28 20:25:08 miniupnpd[744]: HTTP listening on port 44623
May 28 20:25:08 miniupnpd[744]: Listening for NAT-PMP traffic on port 5351
May 28 20:25:13 WAN Connection: WAN was restored.
Seems like I need to reopen that fault then if it's still disconnecting in random intervals. Though I have noticed that it went back to 3-4dB instead or reaching a lot higher when it reconnects. What do you think? Reopen the fault?
29-05-2016 1:22 PM
Well that certainly shows things still are not right. Now, a reminder that unless you can hear some audible noise on the line - and if you can, make a right song and dance about it (not mentioning Broadband) or unless the line is showing a fault on test, you won't get anywhere with your line provider (BT) just for a BB issue. So try the on-line automated test that BT have for phone lines for line rental customers to see if it finds a fault, also if you can hear noise then chase it up.
Remember if your neighbours are still having issues and they can hear noise get them to report phone faults to their providers asap.
30-05-2016 3:04 PM
It's been fairly consistant as of right now with the noise between 3-4dB. WAN went down for five minutes at 8:53AM which unfortunately I went to bed 6:00AM and didn't record as a result.
I guess tommorow I'll wake up at 8:00AM and record it. If nothing happens I think this issue has been resolved.
30-05-2016 3:41 PM
What does a today's RouterStats daytime SNRM graph look like?
18-08-2016 9:35 AM
Just for the record, this post summarises how things went forward. No other real need to add to this thread.
- « Previous
- Next »
