Peak time speed problem - purleigh
- Peak time speed problem - purleigh
09-04-2013 11:02 PM
I have reported many times my issues in the original peak time slow down thread (now locked), but I was largely ignored as it was stated that my problems were not related to the predominating issue, and that I probably had a line fault. The only thing that was ever found was that Plusnet had underestimated the 20CN capacity on an endpoint that I had been connected to, which they say they fixed - but I'm not convinced.
So I am starting again, in the hope of finding what is going wrong - as I can't see where the issue lies !
I am on the Purleigh exchange (EAPUR), and I have never seen that showing congestion or having other problems.
I have a straight line connection of approximately 500 metres from the exchange.
My connection is 20CN ADSL, G.dmt, that is 8128Kbps down, and 448Kbps up.
My ADSL gateway and telephone are plugged directly into the ADSLnation XTE-2005 filtered faceplate on the master socket, using the shortest length and highest quality cables. There are no cable extenders or extension wiring used at all.
My typical gateway stats are as follows -
ADSL driver and PHY status
Channel: FAST, Upstream rate = 448 Kbps, Downstream rate = 8128 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Fast
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 11.8 23.0
Attn(dB): 9.0 5.0
Pwr(dBm): 13.8 11.9
Max(Kbps): 9536 1136
Rate (Kbps): 8128 448
The sync rates are always the same, and the other figures might move +/-0.5dB whatever the weather, and no evening droops.
The error rate currently is in the order of one or two CRC errors per day !.
In an effort to start resolving this issue from scratch, I have done the following -
1) I removed my ADSLnation XTE-2005 filtered faceplate, blew it clean with compressed air & cleaned contacts with meths.
2) Tried different ADSL cable to between the filtered faceplate and the gateway, 50cm round cat5 RJ11
3) Swapped gateways between a Draytek Vigor 2710, and a Netgear DG834GT with DGteam firmware.
4) Replaced my old BT DECT telephone with a new Siemens Gigaset N300A-IP basestation, into the XTE-2005 faceplate.
5) Temporarily used a high quality ADSL inline filter into the test socket, but have gone back to using the XTE-2005 faceplate.
- None of which made the slightest difference !.
I had a line reset applied to my connection at 16:04 on 3rd April 2013, as my exchange had only recently stopped correctly negotiating a workable target SNR, was not updating the BT line profile even with an 8128 sync steady for > 300 hours, and was reporting errors when there weren't any !.
Therefore I am currently in day six of the ten day re-training period, so for a few more days I don't particularly want to swap things around.
The SNR is now holding steady, syncing at max 8128Kbps, and the line has been stable at all times since.
Before Christmas my speedtest results were pretty much always as follows -
Since the line reset I have been achieving typically -
So there is an unexplained permanent increase in latency in the region of 10ms to 15ms.
Since the line reset, the latency remains fairly constant with low jitter - even during the evening speed slowdowns.
My ThinkBroadBand quality monitoring graph also always looks alright -
The purpose of this thread is so that I can post all my test results whenever I experience the illusive peak time slowdown !
Re: Peak time speed problem - purleigh
09-04-2013 11:04 PM
Quote You are currently connected to gateway pcl-ag08.
[quote=BTW Performance Test] Download speed achieved during the test was - 3.61 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
My router looks OK
My BTW profile is 7.15Mbps
The Plusnet profile is 7.15Mbps
I reported all this to 'Kelly', who said -
Quote Loads of capacity on that end point right now so it's not congestion on our side. I can't do exchange checks from here.
and
Quote I can't see anything atm which is causing that. I'll talk to Dave on Monday
which looks like it resulted in my exchange being tested Monday night, as that messed up the estimated line speed !
Quote Phone exchange:
PURLEIGH
Estimated line speed:
2.0Mb (Accurate to within +/- 1Mbit) - Checked on 2013-04-08 21:43:46
Current line speed:
7.15 Mb
which previously always said 8.0Mb !
09-04-2013 11:05 PM
[quote=BTW Performance Test]Download speed achieved during the test was - 2.35 Mbps
My router looks OK
09-04-2013 11:15 PM
It looks to me like either exchange congestion (which nobody has ever found), or my connection endpoint still has limited capacity.
I just can't see any problem with my ADSL connection.
It also bothers me that when running speed tests (during the slowdowns) that the graph of the progression of the speed tests show a particularly 'choppy' shape, whereas under normal conditions the graph is relatively flat with the odd peak.
Here are some I captured previously, although the waveforms are representative of the situation now -
09-04-2013 11:53 PM
10-04-2013 9:15 AM
Is it possible that my telephone exchange is a slave to another ?.
Therefore rather than looking at capacity issues on my exchange, is there a regional exchange which is limiting capacity at peak times ?
10-04-2013 10:10 AM
IPSC capacity has been a bit tight this week due to a problem with one of our gateways over the weekend. We've been bringing that back into balance now its been resolved and also increased our bandwidth limit on the ISPC platform.
This went in yesterday, so I was hoping that you'd see much better performance last night, but it appears not!
Can you do some speed tests tonight again and see if it is still the same?
fixing some awful typos
Ex-Broadband Service Manager
10-04-2013 10:24 AM
I will not be relying on one evening of good results, as there was no slowdown on Saturday or Sunday.
I hope Chris Pettitt can find something more conclusive than the exchange results that he has already provided in ticket #67252255, which were admittedly just before my line was reset - but the line had been stable and near error free for a long time when the later results were taken.
11-04-2013 10:15 AM
11-04-2013 2:07 PM
I ran speed tests every 15 to 20 minutes, between 19:00 and 23:00, and most of the time the results were > 6.80Mbps.
There was a rough patch for ten minutes either side of 20:00, where I thought it was going to fail.
During that period I was doing speed tests every two minutes, and noticed that alternate tests were very slow and the next very fast (above profile !). It almost looked like some odd buffering problem somewhere, and then it disappeared.
While that period was an oddity, if I wasn't posting my observations right now then I wouldn't have complained about it.
Several of the later speed test were very up and down in a sawtooth manner, but were nowhere near as bad as some I've seen.
To summarize, last night was perfectly usable - but Wednesday often are !, and the test results were generally acceptable.
I will endeavor to report back here regularly, and try and capture any future sustained peak time slowdowns.
[Edit :] I split this post for clarity, and the text previously included is now in Reply #11
11-04-2013 2:27 PM
11-04-2013 2:27 PM
when speed test plots look like this-
When the time is outside the evening peak usage range, the speed test plot ramps up to a relatively steady level and then stays pretty much at that level, with the odd small peak and trough, but for the most part is indicating instantaneous speeds which are representative of the final reported result.
However at peak times, the final reported figure seems to be based on the fastest fraction of the test duration and NOT the overall average.
This means you can be observing really bad throughput for 90% of the time and then see a 10% good burst, and only the best 10% part is recorded.
Of course sods law means that I nearly always get a good speed burst during a test.
So with the 'choppy' nature of the plots, I can often observe perhaps -
Progress - Instantaneous speed
0% - Test started
10% - 1.5Mbps
20% - 5.5Mbps
30% - 2.7Mbps
40% - 3.1Mbps
50% - 4.6Mbps
60% - 6.9Mbps
70% - 3.2Mbps
80% - 3.1Mbps
90% - 5.7Mbps
100% - Result recorded = 6.9Mbps
As all the speed test programs appear to operate in this 'best effort' manner, it makes it very difficult to show you test results of concern, which happen not to be very good or consistently bad. In Reply #1 and Reply #2 I was able to capture consecutively bad results using three different testers.
There are many times when I would like to show you results where my line is perfectly stable, but the transferred data speed is crashing from one moment to the next between slow and moderately fast, or when the test is almost at a standstill for 90% of the test only to have the 10% burst cause an unrepresentative result to be reported.
11-04-2013 3:49 PM
11-04-2013 8:40 PM
[quote=BTW Performance Test]Download speed achieved during the test was - 5.56 Mbps
Modem has one CRC error in the last 24 hours, and line stats are -
Status: ShowtimeRetrain Reason: 1
Mode: G.DMT
Channel: Fast
Trellis: ON
Down Up
SNR (dB): 11.4 23.0
Attn(dB): 9.0 5.0
Pwr(dBm): 13.8 11.9
I will test again in half an hour and see if it gets better or worse.
11-04-2013 9:25 PM
[quote=BTW Performance Test] Download speedachieved during the test was - 3.16 Mbps
Modem has zero errors since previous test, and stats are now -
Mode: G.DMT
Channel: Fast
Trellis: ON
Down Up
SNR (dB): 11.5 23.0
Attn(dB): 9.0 5.0
Pwr(dBm): 13.8 11.9
