Peak time packet loss on ptw-bng01
petejackson
Re: Peak time packet loss on ptw-bng01
Last night looked a lot better on the Colombo host links. We understand maintenance was completed by our supplier as a result of our highlighting the issue to them.  It certainly does look like this particular issues was caused by a problem in the wholesale network.
jimbof
I've noticed it appears to have cleared for me, and I didn't drop the "lossy" connection.
Winner winner chicken dinner Smiley
nokiboi39
Unfortunately am still seeing an issue been ongoing since yesterday, am on  pcl-ag02
My Broadband Ping
Kelly
Fixes: 9
I can't see the problem on that graph?  What are you seeing?
Kelly Dorset
Ex-Broadband Service Manager
haltdef
Kelly
Fixes: 9
Yeah, that looks more like it.  Is it affecting your speeds/browsing/gaming etc?
Kelly Dorset
haltdef
Just a bit, seeing 10Mbps down rather than my usual ~45
AndyH
You're latency is quite high 'generally' for FTTC.
Have you had any issues with stability?
haltdef
There's always been a hell of a lot of FEC errors on my line, never been able to convince anyone of a fault. No issues with stability
AndyH
Have you raised it as a fault with PN before? It looks to me like you might have interleaving on.
Which exchange are you on? Any of these http://community.plus.net/exchange-information/ ?
haltdef
I'm on the Dawlish (WWDAWL) exchange, not listed there. Didn't think slightly elevated latency could be classed as a fault? I'm not a gamer so don't care too much, I'm all for throughput gains though  Tongue
Kelly
Fixes: 9
Its the significant variation in latency which is odd. (unless you are downloading or stressing your router?)
Check this fibre graph as a comparison:
http://www.thinkbroadband.com/ping/share-large/9144a3997781d29ef7685536d3280dd3.png
Kelly Dorset
AndyH
How does your IP Profile compare to your estimates (https://www.dslchecker.bt.com/)? Have you seen a general decrease in your speeds?
If you're getting excessive errors on your line which is impacting your throughput performance, then I am sure it will be looked at as a fault - particularly if you are below your line estimates.
haltdef
IP profile is within a mbps of the best estimate. I was the second person on my cabinet, lost about 15Mbps to crosstalk since then. Line's been fine aside from the recent peak time packet loss
haltdef
Seeing packet loss again tonight, seemed to be resolved the past couple of evenings. Am I experiencing a different issue or has the original one not been fully resolved?
