Peak Time Latency Spikes
- Peak Time Latency Spikes
21-03-2013 11:53 PM
Quote from: Chris Anyone still experiencing issues it would be really helpful if you could start your own threads in Broadband and Routers now, this one has got a bit unwieldy and whilst it contains a lot of useful information it'll be easier for us to look at the remaining few problems separately (while keeping this thread in mind of course).
As per the instructions above, created new topic here.
I stumbled on this http://www.thinkbroadband.com/tools/traceroute.html
Wouldn't this information be more helpful to point to a problem node, along with other information?
Re: Peak Time Latency Spikes
22-03-2013 8:10 AM
It's the routing of a connection through BT's network that we can't see and know if that is causing or contributing to the peak time slow downs still experienced by some people.
22-03-2013 8:13 AM
22-03-2013 3:47 PM
This has been happening all this week, not just during peak time. I've tried the gateway hop but I can't seem to improve it.
I used to have a pretty good response from both speedtest.net and pingtest.net sites.
Although now speedtest.net is sluggish to download, it reports back that latency is around the 35-40ms mark
Confusing huh?
And my monitor looks pretty good to me:
Am I actually looking at this a bit too deep for my own good?
22-03-2013 6:29 PM
Which exchange are you on? Apart from this week, have you had any speed/ping issues before then?
22-03-2013 8:14 PM
I do all my testing wired and I'm currently on ptw-ag03
I noticed it this week.
I've been following the "ping latency" problem since the beginning of the year, so I've been keeping an eye my stats for a while
25-03-2013 10:42 AM
How have things been?
26-03-2013 2:22 PM
If there is congestion at my cabinet/exchange how would I find this information out?
26-03-2013 2:51 PM
Don't think there's any public facing ways but I've just had a look for you and it's green as far as 21CN capacity goes. As for the increase in ping times, it looks like interleaving's been enabled for a while so unless there are now more errors on the line than previously I can't think of any other reasons unless the server being used for the ping tests has changed.
Either way unless it's interfering with your use of the service it's not anything to worry about.
26-03-2013 3:22 PM
So what would have caused the regular peaks, and the huge packet loss just after mid-day, and the biggest peak at 10pm?
I would have thought it should have resembled Ping26-Mar.jpg although that is showing minor regular blips.
(not even a wired PC being used, or phones or laptops! Just the router)
