Peak-Time Connection Problems
- Re: Peak-Time Connection Problems
- « Previous
- 1
- 2
- Next »
26-03-2009 10:09 PM
Hey, here's another interesting tracert - I wonder why my streaming speeds on YouTube suck..
Tracing route to www.youtube.com [208.117.236.74]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms . [192.168.2.1]
2 35 ms 44 ms 45 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 37 ms 35 ms 166 ms ge0-0-0-504.pte-gw2.plus.net [84.92.4.90]
4 35 ms 44 ms 40 ms 195.66.224.185
5 106 ms 106 ms 106 ms te2-2.ccr01.jfk02.atlas.cogentco.com [130.117.1.105]
6 105 ms 102 ms 110 ms te3-3.mpd01.jfk01.atlas.cogentco.com [154.54.1.210]
7 111 ms 125 ms 112 ms te4-4.mpd01.ewr03.atlas.cogentco.com [154.54.1.38]
8 124 ms 124 ms 124 ms you-tube-llc.demarc.cogentco.com [38.101.84.66]
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 181 ms 182 ms 181 ms youtube.l.google.com [208.117.236.74]
Trace complete.
Oh. I'll tracert Youtube again after 0000 and I suspect those hops will actually work.
How do I go about getting this investigated properly? I've consulted a few different forums and no-one seems to have any idea what could be causing it.
Trace complete.
Message 16 of 20
(314 Views)
26-03-2009 10:26 PM
Youtube not being able to cope with demand?
Tracing route to portal.plus.net [212.159.8.2]
1 <10 ms 1 ms 1 ms voyager.home [192.168.1.1]
2 40 ms 37 ms 42 ms lo0-homesurf.ptn-ag2.plus.net [195.166.128.54]
3 40 ms 38 ms 48 ms ge1-0-0-205.ptn-gw01.plus.net [84.92.3.97]
4 91 ms 221 ms 202 ms gi0-2-32.ptc-gw1.plus.net [195.166.129.10]
5 53 ms 54 ms 61 ms pos1-0.pih-cr1.plus.net [195.166.129.250]
6 50 ms 48 ms 49 ms vlan7.pih-gw3.plus.net [212.159.0.26]
7 48 ms 54 ms 81 ms if25.pih-lb04.plus.net [212.159.0.18]
8 84 ms 48 ms 50 ms portal.plus.net [212.159.8.2]
Trace complete.
Trace complete.
Message 17 of 20
(314 Views)
27-03-2009 2:31 AM
Hops not responding to a tracert ping don't necessarily indicate a problem; routers are there to route and should give that priority.
If the routers are busy ping requests can timeout as was happening on the way to YouTube. Since the YouTube server did respond to each of the 3 probes the intermediate routing must have succeeded.
David
Message 18 of 20
(314 Views)
27-03-2009 10:04 AM
You're right, and after the result came back the same even after streaming speeds returned to normal I realised I was jumping the gun trying to find anything that might explain it.
Oh well, back to the drawing board.
adie:quote
adie:quote
Message 19 of 20
(314 Views)
01-04-2009 2:51 PM
Since two weeks I have terrible pings,usually after 4 pm, but today since morning.
In the evening I can get pings up to 8000ms.
Example:
traceroute to google.co.uk (66.249.93.104), 30 hops max, 38 byte packets
1 www.routerlogin.com (192.168.0.1) 0.722 ms 0.546 ms 0.452 ms
2 lo0-plusnet.pte-ag2.plus.net (195.166.128.72) 359.562 ms 493.118 ms 550.890 ms
3 * ge0-0-0-504.pte-gw2.plus.net (84.92.4.90) 1001.133 ms 42.764 ms
4 195.66.224.125 (195.66.224.125) 359.059 ms 88.191 ms 371.564 ms
5 209.85.252.40 (209.85.252.40) 379.930 ms 209.85.252.42 (209.85.252.42) 373.435 ms 701.122 ms
6 216.239.43.123 (216.239.43.123) 473.369 ms 331.714 ms 209.85.241.84 (209.85.241.84) 542.880 ms
7 216.239.43.123 (216.239.43.123) 598.228 ms 72.14.233.114 (72.14.233.114) 87.430 ms 695.401 ms
8 209.85.255.23 (209.85.255.23) 745.042 ms 274.000 ms 72.14.233.79 (72.14.233.79) 343.316 ms
9 216.239.47.25 (216.239.47.25) 440.932 ms ug-in-f104.google.com (66.249.93.104) 206.820ms 396.635 ms
Example:
Message 20 of 20
(314 Views)
- « Previous
- 1
- 2
- Next »
