Pathetic Plusnet speed
- Re: Pathetic Plusnet speed
23-12-2012 5:47 PM
I've given up trying, two months of trying to get a reasonable download speed from Plusnet (4 to 8 mbs) , complete waste of time trying to get help, today's reading 0.41. Roll on March, I'm off. Roy
Message 1 of 8
(2,121 Views)
7 REPLIES 7
23-12-2012 7:30 PM
What has PN done to resolve the fault so far?
Message 2 of 8
(678 Views)
23-12-2012 7:38 PM
Welcome to the forum rminson
Would you like to post some stats from your router and from here https://portal.plus.net/my.html?action=data_transfer_speed
Message 3 of 8
(678 Views)
23-12-2012 7:46 PM
I was connected at 7770kbps with 5db margin yesterday, now its 3048kbps with 0.4db margin. I expect it to disconnect any second now and reconnect even lower. I am still awaiting a reply to the latest fault, but they have been ongoing since the beginning of December. Also, my Plusnet profile is lower than my BT speed checker one, and has been for several days. I let them know, replied today to my ticket refusing to update it stating my router was at fault for giving them misleading information?
Luckily I am not on a contract. Sky have unbundled my exchange recently but I'll research them after Christmas. They have always been good with the TV service, but what they're like with telephone and broadband I'll have to research.
I understand a fault is a fault, and try to be fair but after many weeks patience begins to wear thin.
- for information, I disconnected twice whilst writing this.
Message 4 of 8
(678 Views)
23-12-2012 10:02 PM
Are you connected to the test socket?
Message 5 of 8
(678 Views)
28-12-2012 5:27 PM
Quote from: rminson I've given up trying, two months of trying to get a reasonable download speed from Plusnet (4 to 8 mbs) , complete waste of time trying to get help, today's reading 0.41. Roll on March, I'm off. Roy
It's almost certainly the result of all of the disconnections on your line (although seems to have been stable for over a day now):
Session Started Session Ended Session Duration
11:19 27/Dec/2012 N/A One Day, 5:39:53 (on going)
11:02 27/Dec/2012 11:17 27/Dec/2012 0:14:58
19:26 24/Dec/2012 10:39 27/Dec/2012 2 Days, 15:12:36
19:19 24/Dec/2012 19:25 24/Dec/2012 0:5:41
19:24 23/Dec/2012 19:18 24/Dec/2012 23:54:29
19:16 23/Dec/2012 19:22 23/Dec/2012 0:6:6
18:56 23/Dec/2012 19:15 23/Dec/2012 0:19:27
15:40 23/Dec/2012 18:55 23/Dec/2012 3:14:59
13:45 23/Dec/2012 15:38 23/Dec/2012 1:53:4
13:34 23/Dec/2012 13:44 23/Dec/2012 0:10:16
10:36 23/Dec/2012 13:33 23/Dec/2012 2:56:28
11:21 22/Dec/2012 10:31 23/Dec/2012 23:10:18
17:14 21/Dec/2012 11:19 22/Dec/2012 18:5:16
09:11 21/Dec/2012 17:13 21/Dec/2012 8:2:14
15:46 20/Dec/2012 09:10 21/Dec/2012 17:23:42
This is playing hell with BT Wholesale's line profiling systems and seriously limiting your speed. I can see you've raised a few faults with us but none have really been carried through to resolution? Ideally you'd need to be plugged into your main socket for a number of days to see if the drops continue. If they do then we need to get an Openreach engineer out as we almost did a while back. If they don't then it's your extension wiring, or some aspect of it, that's at fault.
Only once the line's stable can we look at sorting out the profiling. As long as the drops continue you're going to have problems.
Quote from: will2012 I was connected at 7770kbps with 5db margin yesterday, now its 3048kbps with 0.4db margin. I expect it to disconnect any second now and reconnect even lower. I am still awaiting a reply to the latest fault, but they have been ongoing since the beginning of December. Also, my Plusnet profile is lower than my BT speed checker one, and has been for several days. I let them know, replied today to my ticket refusing to update it stating my router was at fault for giving them misleading information?
Another problem with the line dropping connection:
N/A 6:9:35 (on going)
10:55 28/Dec/2012 20:40:39
14:13 27/Dec/2012 0:13:49
13:57 27/Dec/2012 2 Days, 2:5:59
11:47 25/Dec/2012 0:1:24
11:44 25/Dec/2012 1:1:30
10:41 25/Dec/2012 0:0:9
10:34 25/Dec/2012 0:4:11
10:29 25/Dec/2012 0:19:40
10:08 25/Dec/2012 0:9:37
09:57 25/Dec/2012 0:26:1
09:30 25/Dec/2012 0:0:53
09:28 25/Dec/2012 0:13:48
09:11 25/Dec/2012 0:7:51
08:39 25/Dec/2012 0:16:34
08:22 25/Dec/2012 0:4:10
08:15 25/Dec/2012 13:0:51
Your line was 'banded' at ~3mbps because of drops like this. It set the IP profile to 2707kbps where is looks like it's sitting at the moment. I can see a request has been submitted to reset the line attributes again. You're synchronised higher but still have a low IP profile looking at the information this side.
I'd be interested in what a BT Speedtest tells you about you line profile?
Having briskly read through your tickets I think we need to get to the bottom of what's causing the disconnections rather than fiddle with interleaving/line resets (I think your line would be better off with interleaving on BTW in its current state).
Feel free to let me know how things pan out over the coming days and I'll do my best to help get to the bottom of the problem ...
Message 6 of 8
(678 Views)
31-12-2012 3:11 PM
Poor Excuse From Crap BT if you in the range of acceptable speed they cant log a fault with Crap BT because you in the range but im sure BT cap speeds using there crap gear in there exchange .
Message 7 of 8
(678 Views)
31-12-2012 7:35 PM
Quote from: Bob
It's almost certainly the result of all of the disconnections on your line (although seems to have been stable for over a day now):Session Started Session Ended Session Duration
Another problem with the line dropping connection:Session Ended Session Duration
Hi Bob,
Thanks for your reply. Yes, the speed is still very low, but the banding has been removed. I have asked for interleaving to be turned on, but apparently they can't do that as its still in the 10 day training period. I dont know what the technical department are doing to resolve the disconnection issue, your guess is as good as mine. I guess we're waiting for the 10 day training period to expire.
Message 8 of 8
(678 Views)
