Pathetic Fibre speeds better on normal broadband or another company
- Pathetic Fibre speeds better on normal broadband ...
05-02-2014 11:46 PM
I've done the following
Master socket check
Bt wholesale speed and line Check
Plugged direct into modem
Disconnect all other phone devices ,
Reset router
There's no hissing cracking or pops
No drop outs when incoming or outgoing calls
The fault is either the router /modem
Or it's the package from yourselves
I feel the product I'm purchasing and your supposed to be providing is legally unfit for purpose ! I will be cancelling all payments to yourselves unless this issue is rectified within 48 hrs
STOP LETTING YOUR CUSTOMERS DOWN ! I was with Madasafish for over 16 yrs before the push onto yourselves and I'm very disappointed with the move and wish I was still with Madasafish
Re: Pathetic Fibre speeds better on normal broadband or another company
06-02-2014 2:29 AM
In regards to equipment, if its a persistant problem for you with the speeds being so low, try a friends router. My sister was with plusnet for adsl2+ and every 6months or so, their router would literally just pack in.
Had to get 2-3 replacements. So best thing to do is outrule the router (its kinda hard with Fiber as i wouldnt even know where to begin to tell you which to use.)
Is the support ticket you made a Fault report or just a normal ticket? Judging by fault reports it does take about 2~days for a reply (thats what i waited for and that was with a bump from someone on the forums)
06-02-2014 7:55 AM
06-02-2014 9:06 AM
Quote The fault is either the router /modem
Unfortunately there's a fair bit more that it could be, including the line, the cabinet, the exchange.
Quote and before they. Use the fair usage policy
We don't have a fair usage policy on Unlimited, if we did we couldn't sell it as Unlimited.
I understand you're frustrated but we're not doing anything to deliberately slow you down, why would we do that?
From reading the posts on here, and the ticket it sounds like a fault somewhere along the line or possibly at the exchange. We'll get our faults guys to pick it up and see what's going on.
06-02-2014 9:17 AM
34.1 Mbps on the downstream
6.0 Mbps on the upstream
The speedtests that you did directly connected into the modem, is that when you're seeing 4-8Mb?
11-02-2014 11:36 PM
11-02-2014 11:46 PM
11-02-2014 11:51 PM
12-02-2014 10:41 AM
As I've said in two other threads, your Fault Ticket will be looked at and responded to shortly.
12-02-2014 2:55 PM
Quote from: quitescary ...omplaints of speed they always seem to say the fault is with the customer or bt but nothing to do with them ?
How come so many complain about the same issue ?
Because invariably...
1 The fault is with the customer's internal wiring, especially with ADSL
Or
2. The fault is with the D-Side cable between the house and the street cabinet / the fiber card or E-Side cable / exchange equipment / BT back bone network
Not until the connection touches PN equipment could a SYNCH speed fault be a PN caused issue. That is why the issues are predominantly found in the BTOR owned infrastructure which is shared by nearly all ISPs. As ever, many people are not overly comfortable with the truth, they simply want someone to blame. The bottom line is that in many areas (especially rural ones) the D-Side cables are in a poor state of repair.
Just to be clear, an issue with DATA speed could readily be a "problem" with PN's sstems if (for whatever reason) the IP profile is different to that set by BT.
