Page cannot be displayed
- Page cannot be displayed
04-02-2010 3:00 PM
Help!
I've just joined Plusnet and cannot access the internet after spending an hour on the phone to tech support. I used to be with Sky and i've removed firewall and all applications that stop pop-ups.
Changed the settings as per the tech support team and in the end was told it is a hardware error but it was fine before i moved to Plusnet.
All the router lights are green and i have had confimed connection.
Anyone have any other idea's as i'm currently paying for broadband i cannot access!
Message 1 of 9
(1,354 Views)
8 REPLIES 8
Re: Page cannot be displayed
04-02-2010 3:07 PM
Are you connecting via a "wired" connection between the computer and the router? ..... or using Wire less.....connection to router?
Message 2 of 9
(666 Views)
04-02-2010 3:17 PM
Moderators Note
Topic moved to raise it's profile.
Message 3 of 9
(666 Views)
04-02-2010 3:26 PM
Which router are you using
Message 4 of 9
(666 Views)
04-02-2010 3:33 PM
Hi Doomraider,
If you're still using the Sky router (are these still Netgear boxes?) it may be that the firmware is locked to sky, though I'm not sure whether that would stop you from entering your username and password or if the connection would fail as a result. What's the router reporting as regards the connection?
I believe if you update the firmware to a regular version (firmware should be available from the manufacturer's website) this should remove the issue, assuming that you have the sky Netgear router - apologies if not.
Are you seeing any error messages, and is the computer showing a successful connection to the router?
Message 5 of 9
(666 Views)
04-02-2010 3:47 PM
Welcome to the forums BTW Doomraider
Message 6 of 9
(666 Views)
04-02-2010 4:34 PM
Thanks for your help and cheers Strat it's nice to be here. I am using the Thompson router supplied by Plusnet and the computer showing a successful connection to the router. It's a desktop pc not wireless and the BT line is not a new line but a new connection as i only moved in recently.
Message 7 of 9
(666 Views)
04-02-2010 4:40 PM
I can see connections from yesterday but not today.
Does your router control panel state that you're connected?
Message 8 of 9
(666 Views)
04-02-2010 4:58 PM
Hi Mand, yes it says i'm connected (although i'm not on the pc currently as i'm at work)
I'm looking forward to telling people about Plusnet as i feel these bigger broadband companies are pulling in a high percentage of custom yet not giving the customer service/tech support/.
Any help would be appreciated.
Message 9 of 9
(666 Views)
