Packet loss in evenings, 21CN ADSL
- Packet loss in evenings, 21CN ADSL
Re: Packet loss in evenings, 21CN ADSL
16-01-2014 8:27 PM
31-01-2014 3:03 PM
Have you got anywhere with sorting out the packet loss?
31-01-2014 3:33 PM
30 Jan 2014
Last updates on ticket #79943732
Quote ......
BOT - DSL Logged Faults
1:28pm, Monday 27 Jan 2014
I am sorry to see that you are experiencing a speed fault.
I have raised this issue with our suppliers.
They have a standard lead time of 48-72 hours to provide a response however we will check for updates sooner and contact you as soon as one is available.
Script User - Automated Script Pool
2:05pm, Thursday 30 Jan 2014
We would like to inform you that your Help Assistant Question [ 79943732 ] has now been returned to the BOT - DSL Logged Faults ADSL2 - Speed pool. A member of our Support Team will investigate your issue as soon as possible.
31-01-2014 8:24 PM
01-02-2014 8:38 AM
Outcome will be "No fault found".
01-02-2014 5:22 PM
ping -t ntp.plus.net
do you see lost packets at any time of the day?
01-02-2014 5:57 PM
Ping statistics for 212.159.13.49:
Packets: Sent = 30, Received = 27, Lost = 3 (10% loss),
Approximate round trip times in milli-seconds:
Minimum = 8ms, Maximum = 20ms, Average = 10ms
C:\Users\admin>pathping ntp.plus.net
Tracing route to ntp.plus.net [212.159.13.49]
over a maximum of 30 hops:
0 PMB1.home.gateway [192.168.0.1]
1 home.gateway.home.gateway [192.168.0.101]
2 lo0-central10.pcl-ag04.plus.net [195.166.128.185]
3 link-a-central10.pcl-gw01.plus.net [212.159.2.172]
4 xe-0-2-0.pcl-cr01.plus.net [212.159.0.204]
5 po2.pcl-gw01.plus.net [195.166.129.41]
6 vl63.pcl-lb01.plus.net [212.159.2.252]
7 * cdns01.plus.net [212.159.13.49]
Computing statistics for 175 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0 PMB1.home.gateway [192.168.0.1] 0/ 100 = 0% |
1 0ms 0/ 100 = 0% 0/ 100 = 0% 192.168.0.101 8/ 100 = 8% |
2 20ms 13/ 100 = 13% 5/ 100 = 5% lo0-central10.pcl-ag04.plus.net [195.166.128.185] 0/ 100 = 0% |
3 10ms 8/ 100 = 8% 0/ 100 = 0% link-a-central10.pcl-gw01.plus.net [212.159.2.172] 0/ 100 = 0% |
4 10ms 15/ 100 = 15% 7/ 100 = 7% xe-0-2-0.pcl-cr01.plus.net [212.159.0.204] 0/ 100 = 0% |
5 8ms 8/ 100 = 8% 0/ 100 = 0% po2.pcl-gw01.plus.net [195.166.129.41] 5/ 100 = 5% |
6 9ms 13/ 100 = 13% 0/ 100 = 0% vl63.pcl-lb01.plus.net [212.159.2.252] 1/ 100 = 1% |
7 9ms 14/ 100 = 14% 0/ 100 = 0% cdns01.plus.net [212.159.13.49]
Trace complete.
01-02-2014 6:25 PM
I'd also have a ping -t (not a pathping) running ready for when he arrives and show him the lost packets.
Does increasing the packet size affect the rate of loss?
01-02-2014 7:00 PM
01-02-2014 8:40 PM
Quote Does increasing the packet size affect the rate of loss?
Seems much the same when using 32 bytes and 2048 bytes.
Have set up a TBB ping monitor on my neighbour's Sky LLU connection. It is showing no packet loss, mine is now near 20%.
03-02-2014 4:02 PM
04-02-2014 10:02 AM
04-02-2014 10:08 AM
http://usertools.plus.net/@gateway/
04-02-2014 10:09 AM
Have tried different gateways, it made no difference to the packet loss.
04-02-2014 8:55 PM
But reading this forum and from personal experience plusnet will always try and point the finger at your connection ,they are never as quick to accept that it could be down to their network, topology , or their masters BT wholesale, that's the impression that i get
