PPPoE / PPPoA?
- PPPoE / PPPoA?
- « Previous
- 1
- 2
- Next »
Re: PPPoE / PPPoA?
28-08-2013 11:12 AM
Bob.
Re: PPPoE / PPPoA?
28-08-2013 4:26 PM
I think I'll try using the DG834G as a modem and connect it to the Asus. Is it simply a case of accessing the hidden page, setting the DG834G to modem only mode, connecting it to the ASUS and then going through the ASUS set-up? I'm keen to be able to get at the line stats so how would this work (through the ASUS or Netgear)?
Quote from: purleigh If you only have a few ethernet things to connect, I can recommend one of these Netgear GS205 for <£15 which works very well.
@purleigh, yes that would work but I'm trying to get everyting lined up for when we get FTTC. My plan is that I will only need to swap over to a fibre modem once our exchange is enabled.
Sorry if these are dumb questions but I'm in new territory here
Bob
Re: PPPoE / PPPoA?
28-08-2013 7:06 PM
More or less yes, I've no experinec of doing it but found this which gives a little more info http://blog.crox.net/archives/40-Netgear-DG834-bridge-mode-PPPoE.html
Quote Is it simply a case of accessing the hidden page, setting the DG834G to modem only mode, connecting it to the ASUS and then going through the ASUS set-up?
It won't I'm afraid, you lose access to the DG834, its now just a modem. The same is true for most (if not all) devices when they are acting as modems only. Not sure if it's the same with the DGTeam f/w as purleigh suggested but if it is possible then it would only be by directly connecting to the DG834 and not via the ASUS.
Quote I'm keen to be able to get at the line stats so how would this work (through the ASUS or Netgear)?
Re: PPPoE / PPPoA?
30-08-2013 1:19 PM
I set everything up this morning and it all went remarkably smoothly. Following the instructions at http://blog.crox.net/archives/40-Netgear-DG834-bridge-mode-PPPoE.html, I set the DG834G to modem only mode and by plugging in to one of the LAN ports, you can still log on to 192.168.0.1 and get a cut down menu including the line stats (see screenshot).
I then connected up the ASUS, the auto set-up detected everything correctly and I was up and running
Bob
Re: PPPoE / PPPoA?
30-08-2013 1:43 PM
That's interesting, does it have to be any specific port ? and/or does the router need to be in a specific port ? does the PC you plug in need a static IP in the 192.168.0.x subnet ?
Quote by plugging in to one of the LAN ports, you can still log on to 192.168.0.1 and get a cut down menu including the line stats
Re: PPPoE / PPPoA?
30-08-2013 1:51 PM
The router is plugged in to the DG834G's LAN port 1 (I'm sure I read somewhere that you should use this one but I haven't tested any of the others). I plugged my laptop randomly in to one of the other ports, (port 3 I think), typed 192.168.0.1 in to the browser and it just worked. I didn't change any settings on the laptop.
Bob
Re: PPPoE / PPPoA?
30-08-2013 2:36 PM
- « Previous
- 1
- 2
- Next »
