PPP link down
Scottonpc
PPP link down
The internet connection has disconnected multiple times today, the router logs on the Technicolor TG582n router show the following errors: PPP link down and xDSL linestate down.
Speedtest results:
Ping 11ms
Download 18.42 Mbps
Upload 1.00 Mbps
13 REPLIES 13
Scottonpc
Re: PPP link down
Link Information
Uptime: 0 days, 1:00:56
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.243 / 21.538
Data Transferred (Sent/Received) [MB/GB]: 53,31 / 1,77
Output Power (Up/Down) [dBm]: 11,9 / 0,0
Line Attenuation (Up/Down) [dB]: 9,6 / 21,5
SN Margin (Up/Down) [dB]: 6,7 / 3,7
Loss of Link (Remote): -
Error Seconds (Local/Remote): 3.497 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 2.483
HEC Errors (Up/Down): 0 / 2.955
Mustrum
Fixes: 76
Re: PPP link down
Looks like it back again and at good speeds.
How is your phone line, is it quiet?
Scottonpc
Re: PPP link down
It's fine now
Scottonpc
Re: PPP link down
This is still on going, the router is disconnecting a few times a day with PPP link down and xDSL linestate down errors on the event logs
Scottonpc
Re: PPP link down
This issue has started occuring again, last time it was fixed by adjusting the SNR
Fixes: 157
Re: PPP link down
PPP down is the consequence of the loss of xDSL so you can ignore PPP.
For a 21dB line 21mps is pushing luck for stability. The 3.xdB DS SNRM might be optimistic. If it has been test to 6dB before and the DLM has moved it to 3dB It must be doing so because it thinks the line can take it ... and then some interference comes along and the line drops. How long does it take to recover?
The TG582n is a lovely little router in its day a daemon at hanging on to a marginal ADSL line. Which version of firmware is it running?
It plays nicely with router stats - see the download and set up links below. It will be useful to see what happens on the line just before it drops.
Scottonpc
Re: PPP link down
The line seems stable now and 8.4.4.J firmware
Fixes: 157
Re: PPP link down
That is quite old!! 10.2.2.B is markedly better.
@bobpullen - can this still be updated remotely?
bobpullen
Fixes: 315
Re: PPP link down
Does the router have a USB port?
8.4.4.J firmware is for a device with a USB port.
10.2.2.B is for a device without.
Scottonpc
Re: PPP link down
It does not have a USB port
Scottonpc
Re: PPP link down
Could the firmware be updated remotely? Thanks
Fixes: 157
Re: PPP link down
Did you download, install, configure and run RouterStats?
Setting this up and running it continuously will gather evidence (if required) to support investigation of your intermittent loss of xDSL.
bobpullen
Fixes: 315
Re: PPP link down
Possibly. You'd need to message me the serial number and corresponding account username.
