PN update wordpress.
- Re: PN update wordpress.
05-03-2013 8:57 PM
Hi Plusnet, Just wanted to let you know that your wordpress blog needs updating, It only takes a couple of clicks and should include some improvements.
WordPress 3.5.1 is the new update the site is currently on 3.3.1 (its quite behind.)
URL: http://community.plus.net/
Just wanted to give you a heads up on this.
Many Thanks
Many Thanks
Message 1 of 4
(1,152 Views)
3 REPLIES 3
05-03-2013 9:00 PM
Thanks Wendy, we're aware of this however updating isn't quite as simple as the usual click from the admin interface. We have two Wordpress installs on the Community Site and the SMF install that powers these forums. All three 'talk' to each other and there are also ties back to our CRM systems and our main website when registering etc.
The Wordpress installs also run custom-built plugins that may not be compatible with newer versions and require re-factoring.
It is on our list of things to do.
Message 2 of 4
(422 Views)
05-03-2013 9:11 PM
Ah Ok, As a MU application i guess its checking to see if everything works before deployment. Anyway Glad to hear its on the list of things to do
Message 3 of 4
(422 Views)
05-03-2013 9:20 PM
it's a very long list though
Message 4 of 4
(422 Views)
