PN problems ?
- PN problems ?
- « Previous
- Next »
Re: PN problems ?
12-07-2014 2:05 PM
sorry i will rephrase that SWMBO has decided to tidy my spares cupboard thought it was a empty box ,,,,,,,, went in the bin a few weeks ago
Message 46 of 52
(353 Views)
Re: PN problems ?
12-07-2014 2:14 PM
Regarding the gateway checker, you can try http://usertools.plus.net/@gateway/?debug-ip or http://usertools.plus.net/@gateway_custom/?debug-ip if the debug mode complains that your IP isn't from Plusnet, which it just did with my 46.208.X.X IP address.
Message 47 of 52
(353 Views)
Re: PN problems ?
12-07-2014 2:35 PM
Not from PN using http://usertools.plus.net/@gateway/?debug-ip
Usinghttp://usertools.plus.net/@gateway_custom/?debug-ip
Message 48 of 52
(353 Views)
Re: PN problems ?
12-07-2014 5:06 PM
So it looks like the gateway checker site doesn't work because the necessary hop in the route doesn't respond to the traceroute probes (in the direction inbound to you).
For the gateways it works on, the output looks like:
[tt]Array
[0] => 1 vl50.peh-asr03.plus.net (84.92.0.73) 0.433 ms
[1] => 2 po3.3659.peh-cr02.plus.net (84.93.232.38) 2.530 ms
[2] => 3 84-93-232-60 (84.93.232.60) 9.339 ms
[3] => 4 ae3.ptw-cr01.plus.net (195.166.129.32) 11.093 ms
[4] => 5 te8-5.ptn-gw01.plus.net (212.159.0.113) 9.471 ms
[5] => 6 link-a-central10.ptn-ag02.plus.net (212.159.2.133) 12.345 ms
[6] => 7 *
[7] => 8 *
[8] => 9 *
[/tt]
You are currently connected to gateway ptn-ag02.
[tt]Array
[6] => 7 *
[7] => 8 *
[8] => 9 *
[/tt]
Message 49 of 52
(353 Views)
Re: PN problems ?
12-07-2014 6:22 PM
In the middle of rearranging / adding cabeling
After removing the ADSL cable for approx 2 minutes
Again using http://usertools.plus.net/@gateway/?debug-ip , I am not with PN
However with http://usertools.plus.net/@gateway_custom/?debug-ip , I am now back with PN
Message 50 of 52
(353 Views)
Re: PN problems ?
14-07-2014 1:48 PM
Using a D-Link 3680 for testing
I am getting the same results on ptw-ag01
[code= CMD File= tracert]C:\Users\Media-PC>tracert ntp.plus.net
Tracing route to ntp.plus.net [212.159.13.49]
over a maximum of 30 hops:
1 <1 ms <1 ms 1 ms 192.168.10.1
2 1 ms 1 ms 1 ms 192.168.1.1
3 31 ms 36 ms 30 ms lo0-central10.ptw-ag01.plus.net [195.166.128.195
4 28 ms 29 ms 28 ms link-a-central10.ptw-gw01.plus.net [212.159.2.14
4]
5 28 ms 29 ms 29 ms xe-4-2-0.ptw-cr01.plus.net [212.159.0.240]
6 27 ms 28 ms 29 ms te9-4.ptn-gw01.plus.net [195.166.129.33]
7 29 ms 28 ms 28 ms cdns01.plus.net [212.159.13.49]
Trace complete.
C:\Users\Media-PC>[/code]
It would be nice to hear some thoughts on this, by the DCT ?
4]
Trace complete.
Message 51 of 52
(353 Views)
Re: PN problems ?
14-07-2014 5:27 PM
Which router you use, and whether the router has an issue will have absolutely no bearing whatsoever on whether the gateway checker fails to report your gateway. That will be purely down to the checker itself and PLusnet setting up the correct rDNS entries for new gateways.
Message 52 of 52
(353 Views)
- « Previous
- Next »
