PN network unable to cope with Apple software downloads tonight?
- Re: PN network unable to cope with Apple software ...
22-11-2010 8:05 PM
Normally don't have any problems downloading updated Apple iOS software but tonight it's a whole different matter!!!
None of the Apple iOS software (iPhone, iPad and Apple TV) will download properly tonight.
It's not an Apple problem as I spoken to at least 10 of my friends who have all successfully downloaded the updates (none of which are on PN)
It's now been 2 hours and so far all I've managed is a max of 200Mb for the iPad update.
What's going on PN and why can't your network cope at peak times any more? I'm also supposed to be on a Pro package.
Message 1 of 5
(920 Views)
4 REPLIES 4
Re: PN network unable to cope with Apple software downloads tonight?
22-11-2010 8:50 PM
I'm going for the direct download and getting 535k/s links can be found here http://osxdaily.com/2010/11/22/ios-4-2-download/
Message 2 of 5
(526 Views)
23-11-2010 9:56 AM
Quote from: mitchell20 None of the Apple iOS software (iPhone, iPad and Apple TV) will download properly tonight.
Being on Pro you certainly shouldn't be suffering from these problems!
I notice you disconnected/reconnected around the time you made this post? Did that improve the situation?
If I had to take a shot in the dark then I'd say that you weren't properly authenticated with our traffic management platform. When this happens you're assigned a 'default profile'. This profile doesn't treat Limelight Networks traffic very kindly (which includes stuff downloaded from Apple).
Session Started Session Ended Session Duration
19:56 22/Nov/2010 N/A 13:52:21 (on going)
19:20 22/Nov/2010 19:55 22/Nov/2010 0:35:28 <---- Default profile?
16:30 14/Nov/2010 19:19 22/Nov/2010 8 Days, 2:48:57
Anyway, shout up if things still seem a bit ropey...
Message 3 of 5
(526 Views)
23-11-2010 2:40 PM
I did try re-booting twice so that will explain the disconnects.
Just updated all 3 devices (iPhone, iPad and Apple TV) now and everything went OK. I've now just got a mammoth amount of usage from yesterday (2.2gb) with nothing to show for it 😞
Still not impressed with the service I get from my so called 'Pro' package which obviously is only Pro when the traffic shaping platform works properly (which I have to control over)
Message 4 of 5
(526 Views)
23-11-2010 3:09 PM
Quote from: mitchell20 Still not impressed with the service I get from my so called 'Pro' package which obviously is only Pro when the traffic shaping platform works properly (which I have to control over)
Why, has this happened before? Getting assigned a default traffic management profile is a pretty rare/unlikely occurrence. If you do ever suspect it of happening then a PPP disconnect/reconnect should sort it. If it doesn't, something else is at play and we'd need to investigate further.
Message 5 of 5
(526 Views)
