PN Portal registration problem
- PN Portal registration problem
14-01-2008 11:41 AM
Guys, a problem to pass to web / dev would be that when you register for a bussiness account, and use DD as payment you are asked for the account details, as follows;
First name: [type here]
Last name / Business Name *: [type here]
which is fair enough. So business uses fill in the second half only? Right?
The site wont allow you to leave the first name box blank, and there is no asterisk, so you should be able to.
I've had a few DD's bounced by the back because of this issue.
Message 1 of 4
(952 Views)
3 REPLIES 3
Re: PN Portal registration problem
14-01-2008 11:44 AM
Yep, I've seen this a few times.
Will get it raised now.
Message 2 of 4
(409 Views)
14-01-2008 11:46 AM
I've just spoken to QA and this apparently already recognised as a problem.
They're going to try and see where it currently is and get a fix sorted as soon as possible.
Message 3 of 4
(409 Views)
14-01-2008 11:47 AM
OK, thanks James!
Message 4 of 4
(409 Views)
