Outlook express time outs
- Re: Outlook express time outs
09-07-2008 1:26 PM
For most of today, Outlook express has been returning the following error message:
This repeats several times until it, eventually gives up at whcih point I get
It is true for all my accounts and yet I can still access them via webmail
I've not changed any settings at my end, so wonder if something has changed at PN/F9, or if others are having problems.
Quote Your POP3 server has not responded in 60 seconds. Would you like to wait another 60 seconds for the server to respond?
Quote A time-out occured while communicating with the server. Account '###', sever 'mail.froce9.net, Protocol POP3, Port:110, Secure (SSL): No, Error Number: 0x800CCC19
Message 1 of 7
(1,448 Views)
6 REPLIES 6
09-07-2008 1:29 PM
Reboot both PC and router and see if the problem still exists.
Message 2 of 7
(583 Views)
09-07-2008 1:31 PM
Emphasis mine in the above quote
Is this a typo in your forum post, or is this exactly what you see?
Server should be mail.force9.net not mail.froce9.net
B.
Message 3 of 7
(583 Views)
09-07-2008 1:39 PM
Sorry that's a type on my part. it is force9 and, as I said, was working until late last night.
Since when I've rebooted twice which includes the broadband modem (no router) which made no difference.
Message 4 of 7
(583 Views)
09-07-2008 1:44 PM
1) Do you use Zonealarm, or another firewall package?
2) Did your machine install any "Windows Updates" last night?
The 0x800CCC19 error means the connection to the remote host timed out. I suspect you may have fallen foul of this problem.
B.
B.
Message 5 of 7
(583 Views)
09-07-2008 2:34 PM
I have Windows Update set to manual, so although I've been notified of the patch mentioned in those reports I haven't installed it (and probably won't now)
However, everything seems to be working now! Go figure!
Message 6 of 7
(583 Views)
09-07-2008 5:09 PM
This sort of thing was happening on Monday afternoon
http://community.plus.net/forum/index.php/topic,66367.msg531790.html#msg531790
Message 7 of 7
(583 Views)
