Outlook 2007 - Error 550
- Outlook 2007 - Error 550
01-06-2009 10:38 AM
I'm having some issues around sending emails using Outlook 2007.
I've setup my accounts and can receive emails fine into Outlook, but each time I send an email I get the following:
'Send test e-mail message: The server responded: 550 relay not permitted'
Any ideas.....? The error msg apparently relates to a missing Mailbox....
I've noticed theres been some work done on email and the status is Amber - could this have an impact?
Thanks in advance.
Rgds,
Simon
Thanks in advance.
Rgds,
Simon
Message 1 of 7
(2,437 Views)
6 REPLIES 6
Re: Outlook 2007 - Error 550
01-06-2009 10:46 AM
Hi Simon,
I'd suspect that you're using the wrong SMTP (outgoing email) server for that account.
Mind sharing your server settings with us? Also, let us know which ISP you're connecting to at that time.
Message 2 of 7
(896 Views)
01-06-2009 10:54 AM
My settings are attached....
Rgds,
Simon
jim:blue image modified to hide email address mod:end
Rgds,
Simon
Message 3 of 7
(896 Views)
01-06-2009 11:10 AM
Simon,
I hope you don't mind but I have hidden your email address.
As your email address isn't a Plusnet one can you confirm that you are currently connected via Plusnet
Message 4 of 7
(896 Views)
01-06-2009 11:12 AM
I'm not connected via PlusNet at the moment - using internet connection at work - could this be the problem?
The domain is registered via PlusNet.
Rgds,
Simon
Rgds,
Simon
Message 5 of 7
(896 Views)
01-06-2009 11:18 AM
Yes - that login only works from your Plusnet connection.
if you want to send from your works connection you would need to change the outgoing mail server to that required by your works account
Message 6 of 7
(896 Views)
01-06-2009 12:12 PM
Or you could click the 'More Settings' button and select the option to use a username and password for your outgoing mail. The username would be 'sbullough' along with the default password for your account.
Message 7 of 7
(896 Views)
