Ouch!
- Ouch!
Ouch!
25-02-2010 11:25 AM
I thought that down loads were taking a long time, did anyone get the 20 file updates yesterday? for me a few HOURS on so-called Broadband. Looked this morning and what did I find, 129kbs!!! download on My Broadband. After the disaster on Dec 8th, my speeds have crept up to be fairly steady around 1400ish over months. I have not looked at Voyager 210 yet but will do so shortly. Has anyone else been bitten by this bug?
colintivy
adie:orange All caps title removed as per link:rules]
Re: Ouch!
25-02-2010 11:33 AM
Re: Ouch!
25-02-2010 11:59 AM
Router rebooted. Before that, I looked at the stats;-
5 Feb 10 Download 25 Feb10 Download (All upload not very different.)
Line Rate 2144kbs 160kbs
Noise margin 12.9dB 23.0dB
Line Atten 39.0dB 38.0dB
O/P Power 16.6dBm 11.2dBm
K(DMT frame) 68 6
R(check bytes RS code) 12 16
S(RS code DMT frame) 2 16
D(Interleaver depth) 8 1
Are these useful?
colintivy
Re: Ouch!
25-02-2010 12:10 PM
Rebooting has given me a line rate 1856kbs, Noise Margin 15.6db O/P power 15.9 dBw
So that is a bit better. What mught have happened on the 17th do you think?
colintivy
Re: Ouch!
25-02-2010 12:27 PM
Re: Ouch!
25-02-2010 12:55 PM
colintivy
Re: Ouch!
01-03-2010 5:03 PM
Just to let you know that downloads are back up to 1400 again. Thanks for your encouragement and help.
colintivy
Re: Ouch!
01-03-2010 5:15 PM
Re: Ouch!
04-03-2010 11:16 AM
colintivy
Re: Ouch!
17-03-2010 3:38 PM
A relapse of original performance. I go away for the weekend and what do I find? Back to abysmal I am afraid! Can't be more exchange problems can it???
colintivy
Re: Ouch!
19-03-2010 1:37 PM
colintivy
Re: Ouch!
19-03-2010 2:03 PM
Re: Ouch!
22-03-2010 11:49 AM
Re: Ouch!
22-03-2010 3:22 PM
colintivy
Re: Ouch!
23-03-2010 5:14 PM
Managed to get bt at last (my time a bit limited, not theirs) DSL Con Rate 2336Kbps Down, 448Kbps Up Like what you found
Achieved speed 1717Kbps Profile 2000Kbps. Seems to be holding up despite another drop-out a day ago. All looking good I hope.
Only found that Noise margin now has dropped from around 23.8db (when things were dire) to 15.3 for some reason.
colintivy
