Order for ADSL2+ regrade not done
- Order for ADSL2+ regrade not done
12-04-2011 9:34 PM
Can a Plusnet staff member let me know what has happened to this order, please?
Thanks.
Re: Order for ADSL2+ regrade not done
12-04-2011 9:56 PM
Not sure why you were told the 12th on the 6th, as the order was clearly not in a status to confirm this. Though per the above, I can't see all records, so not going to term it as a "lie" just yet
The order has passed the point of no return, so I do not see any reason why this will not be completed within the next 24 hours.
This is a status reached when a order cannot be cancelled unless the line proves faulty during the actual work. This can only occur at the very end of the day two days before (EOD on 11th).
12-04-2011 10:05 PM
Many thanks.
13-04-2011 12:21 AM
Checking DSL Type (if shown and sync speed shown in your router stats should confirm the change has taken place.
If you check closed tickets in your Member Centre you should find a regrade request ticket and service notice which gives dates supplied by BT for the changeover.
13-04-2011 10:22 AM
14-04-2011 1:20 PM
14-04-2011 10:18 PM
15-04-2011 10:46 AM
It looks like it's all complete now with your profile showing as 17000k.
Jojo
15-04-2011 11:53 AM
I've been on ADSL2+ for a three days now and I've seen one contant sync rate, with no restarts, in that time. I have seen none of the expected "training" activity so far. Is that normal?
Thanks,
Mark
16-04-2011 10:34 AM
16-04-2011 11:38 AM
Regrades from ADSL to ADSL2+ have the ability to carry much of the known line data across and factor this into the dynamic line management calculations.
This does not mean there is no 10 day training period, but both direct impact and initial drops are minimised.
Some customers may never see a drop due to this.
