Orange main light and red flashing broadband symbol
- Orange main light and red flashing broadband symbo...
21-04-2021 8:48 PM
My internet has stopped working, the light is flashing orange on my hub and the red letter b is flashing.
I have tried all the troubleshooting. I am not sure what too do now.
Message 1 of 4
(525 Views)
3 REPLIES 3
Re: Orange main light and red flashing broadband symbol
22-04-2021 12:05 AM - edited 22-04-2021 12:06 AM
Welcome to the community. What have you checked out so far?
Message 2 of 4
(512 Views)
22-04-2021 1:07 PM
Thanks!
I’ve tried turning it on and off, unplugging it, leaving it off for a while, turning back on.
I have no home phone so can’t really test if it is the phone line that is the issue where of course the router plugs into.
Is there a local outage ?
It’s been fine since I got it in October 2020, I haven’t moved it at all or touched any wires.
It just randomly stopped working and showed these lights 2 days ago.
Do you work for Plusnet ?
Thanks!
Message 3 of 4
(487 Views)
22-04-2021 2:58 PM
I suggest:
- Log into your router and check that >Advanced Settings >Broadband username, is not corrupted it ought to look like yourusername@plusdsl.net
- You can raise a fault online at https://faults.plus.net or if you have a Plusnet SIM dial 500, or from any phone dial 0800 432 0200 or 0800 328 4677. You will need your user name and password.
You can look up Service status here Service Status
I am not a Plusnet employee.
Message 4 of 4
(472 Views)
