Orange light and orange b icon
- Orange light and orange b icon
23-09-2020 10:08 AM
Rather frustrating when I am working from home.
The router is showing a solid orange light and the b icon is orange too.
I have restarted the router numerous times, turned it on and off and done a factory reset. Nothing is working.
The router is plugged into the master socket. No issues with the phone line. Purely just the internet.
Cannot complete any of the configuration through the hub manager due to lack of internet connection.
Any help please?
Re: Orange light and orange b icon
26-09-2020 10:54 AM - edited 26-09-2020 10:55 AM
Hey @gary_sharrock,
Thanks for reaching out to us here.
I'm sorry to read you were having trouble with your connection and I apologise for the frustration caused. On running a GEA test over your connection it looks like some of the details for your login are incorrect, please follow the below steps:
1) To connect to your Hub One, you will need to open a browser and go to http://192.168.1.254
If you have any issues doing this via Wireless, we recommend trying to do it via Ethernet cable instead.
2) You should come to a page with information about your connection, click 'Settings' at the top and it will ask you to sign in with a Password. This is located on the back of your router under 'Admin Password'
3) Select the option for 'Broadband.'
4) You will see some default options, if not, please press 'Disconnect' on the right and this will allow you to change the Username and Password.
5) For your username, this should be your account username and should be in the following format: (accountusername)@plusdsl.net
Your password is your account password
6) Press 'Connect' and you should be online.
Thank you.
