Opening Ports Issues on 2704N
- Opening Ports Issues on 2704N
18-01-2016 10:06 PM
Hello,
This is really frustrating and was wondering if anyone else has had the same issue, i have opened all the ports needed on my router to connect my server but ports 110 and 1723 will not let traffic through, under port forwarding its showing as done but there not, all the other ports i have opened work like 25, 80, 443 . I have done this many times and never had an issue. To me without much experience on these router i think the router is faulty. Anyone any ideas or seen this before,
Many Thanks
Simon
Many Thanks
Simon
Message 1 of 6
(1,060 Views)
5 REPLIES 5
Re: Opening Ports Issues on 2704N
19-01-2016 12:47 PM
Check your Plusnet firewall settings, just in case. http://www.plus.net/support/security/firewalls/broadbandfirewall.shtml
Message 2 of 6
(517 Views)
19-01-2016 1:05 PM
Presumably your servers respond when you try to access them locally using these ports?
Message 3 of 6
(517 Views)
22-01-2016 9:27 AM
Quote from: aesmith Check your Plusnet firewall settings, just in case. http://www.plus.net/support/security/firewalls/broadbandfirewall.shtml
I have checked there and its off
Message 4 of 6
(517 Views)
22-01-2016 9:27 AM
Quote from: Bob Presumably your servers respond when you try to access them locally using these ports?
yes I can connect from other devices from that port to the server,
I have noticed that when I set it to TCP then log back into the router its changed to UDP by its self,
Message 5 of 6
(517 Views)
22-01-2016 10:19 AM
That is odd
Perhaps something is using UPnP to open sessions across those ports? I've not encountered this issue before and haven't got a 2704 at hand to mess around with at present.
Message 6 of 6
(517 Views)
