Open reach modem and air port extreme router
- Re: Open reach modem and air port extreme router
20-11-2013 12:24 PM
So I have the PN router but
Was wondering if I can just cut the middle man and
Hook up the AirPort Extreme to the open reach modem
Like this
http://www.yourmacteacher.com/using-apple-time-capsule-or-airport-with-bt-infinity/
Is it possible as I don't really want 1 modem and 2 routers working
One of each would be better
Many thanks
Like this
Many thanks
Message 1 of 6
(959 Views)
5 REPLIES 5
20-11-2013 12:32 PM
Yes, it will work fine. You will need to configure the PPPoE connection on the Airport with your PlusNet username and password as described here http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml .
Note that link seems to imply you don't need a password for PPPoE but it's wrong, you do! it's the same as the one described for PPPoA.
Message 2 of 6
(560 Views)
20-11-2013 12:39 PM
Thanks mister w for the quick reply
that's great to know
Many thanks
Many thanks
Message 3 of 6
(560 Views)
20-11-2013 12:42 PM
Hi D3lboy,
I'm successfully using the Openreach modem with an Airport Extreme and have no issues.
Hope you get on OK
Hope you get on OK
Message 4 of 6
(560 Views)
20-11-2013 3:56 PM
Thanks Dvorak
Wish I knew before I ordered there router could have saved £5.99 lol
Oh well always something to fall back on
Message 5 of 6
(560 Views)
20-11-2013 4:02 PM
Yeah it's good to have a spare around in case there are any issues in future, it will help to prove whether it's your router or connection.
Message 6 of 6
(560 Views)
