Old linebox
- Old linebox
- « Previous
- 1
- 2
- Next »
Re: Old linebox
10-09-2007 4:22 PM
Quote from: Mand Hi there,
The fees quoted are the charges as issued by BT Wholesale. They are judged to be the cost of sending a BT Openreach engineer to your premises to conduct non-essential work.
Judged by whom?
Quote We cannot refute these charges on an individual basis.
Maybe not but I feel you have a moral obligation to ask for justification on behalf of your customers. Putting yourself in the customers' position, do you honestly consider BT's charges to be realistic - I think not!
Quote Do you ever get any noise on the line at all? If so it may be worth going down the fault route for the voice side of things.
Yes I do but it's very intermittent and I'm not prepared to risk raising a fault.
Regards .....
Message 16 of 24
(372 Views)
Re: Old linebox
10-09-2007 5:00 PM
Quote from: road Judged by whom?
By BT Openreach, who employ the engineers.
Quote from: road Maybe not but I feel you have a moral obligation to ask for justification on behalf of your customers. Putting yourself in the customers' position, do you honestly consider BT's charges to be realistic - I think not!
The fees are standard across the WLR service (the service we buy from BT Wholesale). These are the charges derived from labour, materials, time and such.
If you called out a plumber you would pay a standard call out charge, as well as any other charges incurred as well.
You also have to consider that Openreach only have so many engineers, and need to charge for non-essential work to ensure that demand doesn't far exceed supply.
Quote from: road Yes I do but it's very intermittent and I'm not prepared to risk raising a fault.
Regards .....
It doesn't cost you anything to raise the fault to us and let us test it, you never know what might show up.
Message 17 of 24
(372 Views)
Re: Old linebox
10-09-2007 6:38 PM
I'm asking for justification of the extortionate charges, not for a waiver of the charges. I fully expect to have to pay for work being done but I do not expect to be ripped off.
Regards .....
Regards .....
Message 18 of 24
(372 Views)
Re: Old linebox
11-09-2007 11:04 AM
Quote The fees are standard across the WLR service (the service we buy from BT Wholesale). These are the charges derived from labour, materials, time and such.
Message 19 of 24
(372 Views)
Re: Old linebox
11-09-2007 1:49 PM
Quote from: road I'm asking for justification of the extortionate charges, not for a waiver of the charges. I fully expect to have to pay for work being done but I do not expect to be ripped off.
If PN can demonstrate that there is a fault there is a possibility that you will get it swapped for free. Worth a try!
Message 20 of 24
(372 Views)
Re: Old linebox
21-09-2007 5:36 PM
Quote from: Mand
Regards .....
It's just happened again this afternoon <sigh>.
I was happilly surfing and then, all of a sudden, NADA - I lost my connection with PlusNet and I just could not re-connect. Been here before methinks so I immediately lifted the telephone receiver and lo and behold, there was crackling on the line. The temporary fix is quite simply a matter of un-plugging the filter from the linebox and plugging it straight back in again, which stops the crackling. AFAIC, the linebox is definitely faulty but with it being such an intermittent fault, how do I prove that it needs replacing FOC. If there was noise on the line all the time, it would be simple but I can literally go for months without any problems and then, all of a sudden, wallop!
Regards .....
Message 21 of 24
(372 Views)
Re: Old linebox
21-09-2007 7:24 PM
Ah, good idea, never thought of that. Strange how the simple solutions often elude us, isn't it
Right, my telephone service is with PlusNet so the next time it happens, I'll phone them and hopefully they will be able to hear it and then raise a fault for me.
As for swapping filters, I've tried a shed-load of different ones and it doesn't make any difference.
Thanks for your very helpful suggestion
Regards .....
Regards .....
Message 22 of 24
(372 Views)
Re: Old linebox
21-09-2007 7:35 PM
I think I know the crackling you heard when you have been disconnecting, as I had a similar problem when I was with a previous ISP (I've not read the entire thread though).
I used to be able to (oddly) keep my connection alive by messing around with my phone, and it was eventually tracked down to a fault piece of kit at the exchange (the name of which eludes me for now, anyone want to throw some names around and see if you hit the right one...line card?), which BT replaced and then everything was nice and fine.
Message 23 of 24
(372 Views)
Re: Old linebox
21-09-2007 8:43 PM
Also remember to disconnect your router when making the recording. The first thing that BT will ask you to do is remove the router and see if the problem remains.
Message 24 of 24
(372 Views)
- « Previous
- 1
- 2
- Next »
