Old Tickets / Questions
- Re: Old Tickets / Questions
14-08-2007 4:38 PM
Is it possible to view tickets / questions that are older than two years?
Message 1 of 6
(2,265 Views)
5 REPLIES 5
14-08-2007 4:45 PM
Can I ask if there is a specific reason you may require tickets older than 24 months?
We recently published our data retention policy to the portal to give customers more visibility of the processes we go through.
Message 2 of 6
(656 Views)
15-08-2007 3:26 PM
I'm trying to figure out why we're on our current broadband product. I thought there might have been a ticket for when we signed up to it. I also believe the product may have changed since we signed up aswell so I was looking for some information on that. From "View Transactions" it looks like we signed up for it in February 2005.
Message 3 of 6
(656 Views)
15-08-2007 4:22 PM
Your account history is as follows:
The two products are the same and the change will have been invoked when we had a product refresh here so for all intents and purposes you've been on the same account since you signed up.
Hope this helps!
11th Apr 2006 Product Changed PlusNet Small Business Premier Option 2 (Annual Contract, No Modem)
11th Feb 2005 Account Type Changed PlusNet Small Business Premier - Up to 4Mb (Annual Contract, No Modem)
Hope this helps!
Message 4 of 6
(656 Views)
17-08-2007 3:37 PM
Thanks Bob. I'm still not clear on this though. You say the two products are the same and that we're on the same account, but the original product was "Up to 4Mb" and I believe we're now on an "Up to 8Mb" connection. So something is different.
Also the product we're on now is "Small Business Premier Option 2" but I can't find any information about that product on the site. The closest is "Small Business Premier up to 8Mb" which costs £26.99. However, we're paying £34.99 - the same as "Business Premier up to 8Mb".
We're considering moving to a cheaper product but before we do that I need to clarify why we opted for the more expensive option in the first place.
Message 5 of 6
(656 Views)
17-08-2007 4:15 PM
From memory at one point there where 3 classes to products. Upto 2Mb, Upto 4Mb and Upto 8Mb. PlusNet changed these on one of their product refreshes so they where all Upto 8Mb, but you got more extras else where with the 2 higher priced products. I've had very little to do with the business packages though, so my memory might not be perfectly right. I'm sure someone will correct me if I'm incorrect though.
Phil
Phil
Message 6 of 6
(656 Views)
