Oh no! Not another broadband speed topic!
- Oh no! Not another broadband speed topic!
23-08-2007 11:46 AM
I was a business customer until the start of 2006 and was getting a consistent 2MB ADSL connection without any issues.
I then changed to a residential account on the same phone number when I wound up the company that I ran from my home. At this point, despite being on a 2MB account from Force9, my connection speed dropped to 1MB. I was then upgraded to an "up to 8MB" account but my connection speeds remained at 1MB.
My exchange is Upton Park, London where ADSL Max has been enabled.
The downstream figures reported by my Netgear DG834 router are as follows (downstream/upstream):
Connection Speed: 1152kbps/288kbps
Line Attenuation: 41db/12db
Noise Margin: 27db/29db
So can anyone explain to me why I can only get a 1MB connection?
Regards
Philippe
Re: Oh no! Not another broadband speed topic!
23-08-2007 11:47 AM
Those stats tell me that you are on a fixed speed connection, I'll go have a look and upgrade you to MaxDSL if it is the case.
23-08-2007 11:50 AM
As I thought, you were on a fixed 1Mb connection. I've placed a Max regrade order to complete tomorrow morning, you should start seeing the higher speeds after aronud 10 days.
23-08-2007 12:03 PM
I've raised this issue several times over the past year or so with the F9 support staff and was consistently told that I was on ADSL Max and that it must be the distance from the exchange or capacity issues at the exchange that were causing the low speeds.
The drop in speed when I went from business to residential was explained by higher capacity and lower contention levels for business customers.
So I was on a fixed 1MB connection all along!
Look forward to seeing what happens when I get a Max regrade.
Thanks again.
Regards
Philippe
23-08-2007 12:04 PM
23-08-2007 12:07 PM
Quote from: Chris see which agents need educating
http://community.plus.net/comms/2006/10/09/the-cricket-bat-returns/
Barry
23-08-2007 1:32 PM
24-08-2007 11:21 AM
Connection speed: 6528kbps/448kbps
Line attenuation: 42db/12db
Noise margin: 6db/24db
Over the 10 day period that was estimated for seeing a speed increase, should I remain logged on or should I regularly reboot the router?
Regards
Philippe
24-08-2007 11:23 AM
Hopefully you should now be seeing a notable difference in speed.
I would recommend rebooting your router on a daily basis for the first ten days.
24-08-2007 11:33 AM
I assume that the download speed will fluctuate over the next 10 days while the connection stabilises.
24-08-2007 11:39 AM
Have you rebooted today?
24-08-2007 11:45 AM
24-08-2007 11:46 AM
Hopefully if you reboot again, the speeds should pick up.
24-08-2007 11:47 AM
24-08-2007 12:12 PM
Thanks a lot for your speedy, extremely helpful and effective advice and actions!
Regards
Philippe
