NowSlow but stable - Then, fast and spikey
- NowSlow but stable - Then, fast and spikey
07-07-2011 11:12 AM
Re: NowSlow but stable - Then, fast and spikey
14-07-2011 12:35 PM
14-07-2011 12:51 PM
14-07-2011 1:32 PM
15-07-2011 9:57 AM
15-07-2011 12:12 PM
jim:red All caps removed as per Forum Rules mod:end
15-07-2011 12:19 PM
You have a major problem.
To save me reading back
Are you using the test socket
Have you tried replacing filter/cable etc.
If you haven't already you need to raise a fault
15-07-2011 1:56 PM
Apologies for the Caps Lock being on.
I have just changed the splitter to a brand new one and yes it is pluhgged into the socket where my phone line enter the room which, incidentally is about 2 feet from the modem on my desk. I reconnected and then run the speed test again and it recorded 1648kbps.
I'll raise a fault then. Oh, BTW Thanks for your advice.
15-07-2011 2:43 PM
25-07-2011 3:58 PM
I did start the fault procedure but have today made the above enquiry.
