Now whats wrong with this???
- Now whats wrong with this???
06-06-2014 5:23 AM
Message 1 of 7
(1,181 Views)
6 REPLIES 6
Re: Now whats wrong with this???
06-06-2014 9:19 AM
Hi englishrick,
I'm sorry to hear you're having issues with your connection again. I've checked your Local Exchange data and can't see any widespread issues across the board. I have noticed that a fault was detected at your exchange last night (Ref: BT20115) which required our suppliers to make a change to some of the hardware connected to your parent exchange, this may be the reason for the outage.
Not that I would normally advise this, but a re-sync may do your connection some good now the issue has been cleared and may bring your Minimum Latency back down.
Message 2 of 7
(674 Views)
06-06-2014 12:25 PM
By the looks of it you went from fastpath to interleaved as the latency jump usually results in a jump of 20, DLM probably saw a lot of errors and changed it.
FTTP 500 regrade from Tues 28th November
Message 3 of 7
(674 Views)
06-06-2014 2:22 PM
Bloody great!!!!!!!!! all I need to be interleaved
jim:quote
jim:quote
Message 4 of 7
(674 Views)
06-06-2014 3:18 PM
Interleaving is off still.
Message 5 of 7
(674 Views)
06-06-2014 3:35 PM
Quote from: Chris Interleaving is off still.
Ok Chris I have jumped a few gateways, I'll see how it goes, started another graph but speed tests show ping has gone back down to 12ms...Didn't want to reboot modem as BT speedtest isn't working properly and I cant see at what speed it will have synced at.
Message 6 of 7
(674 Views)
06-06-2014 4:14 PM
Well that looks much better already!
Message 7 of 7
(674 Views)
