Novice needing help!
- Novice needing help!
21-10-2008 9:03 AM
Error 678. The remote computer did not respond.
It says under the broadband WAN Miniport PPPOE.
I have absolutely no idea what any of this means! I have selected the broadband to be my primary connection but it's just not having any of it.
Can anybody help me out!
Re: Novice needing help!
21-10-2008 9:16 AM
If your local area network is connected to the internet on a high speed connection then you have broadband.
You haven't given any details of your setup or location but I'm guessing that you are using a wireless router. In that case, you connect to the router via an ethernet LAN, i.e. the router opens up a network that you can use to connect other computers. Your computer is connected by that network to your ISP at broadband speeds.
21-10-2008 9:22 AM
Anyway, as Geewiz asked, please confirm your equipment and connections first.
21-10-2008 9:28 AM
I am connected via an Ethernet cable and my modem is a BT Voyager 2091 supplied by plus net (it says wireless on it but there are cables coming out of it - I told you I was a novice!).
I figured that I wasn't linked via broadband because it takes a while for pages to load and I like to watch TV online (tv shows and football via streaming sites) and they take forever to load, it play for a couple of seconds and then pauses (buffering I think). I have all the software needed to run these streams so I am completely at a lost. I have just done a speedtestBT (which was advised on here) and the results are:
Downstream 3680kbps
Upstream 448 kbps
IP profile for the line 135 kbps.
I also tried to download an album I bought off iTunes last night and it actually stopped (proably got bored!), even individual songs seem to take forever. It used to be great but in recent times the speed etc has been varied.
21-10-2008 9:40 AM
As this is a new broadband installation my guess is that when you first connected you had an unfiltered phone/dialup modem/Skybox.
This would have given a very low synch speed and hence the IP ratee.
It will take about 3 to 4 days to get back up to 3000kbps if your present synch is maintained
21-10-2008 9:46 AM
21-10-2008 10:17 AM
You'll need to wait up to three days for your IP profile to rise back up - that's just the way BT's systems work!
21-10-2008 10:18 AM
Your router is connected to Broadband. You are using Broadband. BUT it is running VERY slow.
As OldJim says there is a reason for this, but we don't know what it is, it's probably a temporary glitch that has gone away.
Your router is now connected at a good speed, but because of the "glitch" BT's equipment has temporarily slowed your line down; it should clear within 3 days.
Keep an eye on the BT Speed test results. The Downstream/Upstream speeds should stay (roughly) the same and (eventually) the IP Profile (BT's speed control) will increase to around 3000.
The connection between your PC and the router is probably a red herring, ignore it until the above is resolved.
21-10-2008 10:48 AM
I have now put a filter on it so we shall see how that affects the internet connection. What can I say! i am a typically impatient female who just hates gadgets or anything technical!
I thank you so much for helping me out
21-10-2008 10:53 AM
21-10-2008 10:54 AM
Many people double-filter them and find this helps.
21-10-2008 10:59 AM
I actually have a spare filter so maybe I should double filter it to be on the safe side, I may aswell if it won't do any harm.
22-10-2008 9:43 AM
On a personal note: I always used to just leave the sky box un-pluged for the majority of the time anyways (stuff the part of the contract that sais you MUST leave it connected for the first 12 months), and would only plug it in if there was somthing I really wanted to get from the interactive site.
And Oldjim you lucky dawg - I only ever got dialup at 56Kb/s and bellow
22-10-2008 8:42 PM
Quote from: Velveteen Asking for help and more importantly directions is something us females excel at!
Advise from plusnet you should NEVER double filter any broadband products
puddy
22-10-2008 8:47 PM
It is to double filter the non broadband items such as a Sky Box.
It is well known that double filtering some products such as a fax machine can have major benefits.
