Not very happy at all
- Not very happy at all
07-09-2011 12:13 PM
It very annoying to get IP Profile from 14000K to 8000K not very happy overall. Plusnet still investigated with my fault raised two days ago to find out why it kept dropping connection speed.
My line is good enough to get around 12-14 Meg on ADSL2+ but at the moment from ADSL 7 Meg to ADSL2+ 8 Meg, only 1 Meg extra is wrong for my downstream line attenuation 33db.
Also Plusnet and BT will not reset target snr until the fault team get back to me. The SNR still very high at 15.9db (day time) and 16.3db (night time) on the downstream and that is the main reason for low sync rate of 9727K.
BT Speedtester now show one page only with max speed up to 7150K and not showing upstream anymore. Look like BT put me back on ADSL mode.
Re: Not very happy at all
07-09-2011 12:38 PM
My sync started off near 14000 and has slowly dropped to 9725 (sometimes lower) on a attenuation of 29. This has been frustrating me since April and it just keeps on going backwards. I think Plusnet are in the dark just as much as we are about why the speeds are poor for ADSL2+.
I had a call from BT yesterday offering me the world but they couldn't explain why my ADSL2+ speed is half my sisters ADSL2+ speed even though we are on the same exchange 3 doors apart. They just kept going on about how much the BTHH will give me the fastest speeds I can get, which according the thier speedtester is 8meg, but come with us and we "could" get you up to 14 meg.
I am thankful that I have gained just over 1 meg download speed over ADSL and maybe I should just leave it at that because it seems no-one knows or will tell anybody what the problem is.
07-09-2011 12:48 PM
Come on mate, look at the ADSL2+ chart, it say your line attenuation of 29db should get you around 15-16 Meg easy! Mine is 33db as it should get around 13-14 Meg easy. Don't leave it as it were, get it fixed mate! You are paying for ADSL2+ not ADSL !
07-09-2011 1:43 PM
I was first sync of 16433K and now my 14 Meg had gone down to 7.5 Meg ! Back to slow ADSL.
Not very happy at all. Please ask BT to put me back to 21CN ADSL2+ and reset SNR please.
07-09-2011 1:58 PM
Personally looking at the connection logs for your line, resetting the SNR at the moment wouldn't be my next step. We need to push this fault through to our suppliers and get them to resolve the underlying issue.
I know it can be frustrating working through a fault resolution, however simply resetting the SNR each time it increase isn't the way forward. Let us get the fault resolved and then see how the line is performing.
07-09-2011 2:00 PM
07-09-2011 2:04 PM
Quote from: itsme Is the connection on a banded profile?
Sorry whart is banded profile ?
07-09-2011 2:04 PM
07-09-2011 2:05 PM
07-09-2011 2:56 PM
ADSL would be line attenuation of 30db but ADSL2+ would be line attenuation of 33db.
The screenshot show as ADSL mode. I am fed up and seriously consider moved away from Plusnet to other ISP.
07-09-2011 3:19 PM
Your upstream sync rate proves you're still on ADSL2. It's not possible to get a sync above 448 on ADSL Max, unless you're on Max Premium in which case it would be set at 832 - still significantly less than the figure in your image above.
With regard to the engineer, you'll only be charged if the fault is found to be caused by something in your premises. As long as the fault is still apparent with the router in the master socket and all phones etc removed from the line then you've proved it to be outside the premises and won't be charged - that's one of the main reasons why we ask for the tests to be done
Unfortunately we can't actually progress the fault at all if you refuse the engineer visit I'm afraid.
ETA: The line's currently banded between 4Mb and 9Mb due to the disconnections. We could fix that but as the line is still dropping it'd be reapplied almost instantly, so unfortunately we can't do that until the dropping connection issue is fixed.
07-09-2011 3:26 PM
You refuse to reset target SNR on my line so I will consider quit it.
I don't want BT Engineering because I read and hear horror stories of BT Engineering come to property and found no fault and still charged customer £144 plus VAT. That's why I refuse! BT is a conned, misleading and rip off! BT are rubbish!
07-09-2011 3:44 PM
With regards to the engineer fault, we actually vet the charges here before passing them on to customers so if we believe that the engineer notes aren't complete or don't tell the whole story, you won't be billed it.
07-09-2011 3:48 PM
07-09-2011 3:51 PM
Give it a few hours and the SNR reset should start to take effect.
