Not happy with speed, am I being slowed down?
MW45
am I being slowed down? As my download speed only ever seems to be 32 mb/s the BT guy told me my line will support  80meg I am not happy with this slow speed because when I signed up plusnet you told me I would get in the region of 70 meg. This is less than half of what I was told I would get!
20 REPLIES 20
adamwalker
Fixes: 221
Re: Not happy with speed, am I being slowed down?
I'm unable to see any obvious causes for that after running a few checks so I'd advise raising a <a href="http://faults.plus.net/">fault</a> so we can investigate that further for you.
 Adam Walker
MW45
what do I need to do phone up?
thanks
Oldjim
Resting Legend
Fixes: 63
No follow this link - as given in the post above - http://faults.plus.net
pwatson
Are you testing via a wired or wireless connection?  If wireless, then you need to test via a wired connection for a more representative result.
MW45
Ive tried both and both say only about 30mb
dick:quote
chrispurvey
I can see you've raised a fault, did you try the PPPoE connection?
MW45
I have just done a PPPoE test the result is 66.14 Meg download and upload 15.09 meg, which is a lot better, so does that mean my plus net route is faulty?
chrispurvey
It would point toward the router, yes.
Have you tried the router again to see if it any different, if it's a lot slower via the router we may need to get another out to you.
MW45
yes as soon as I plug it back into the router the speeds drops again to about 30 meg,
goldenfibre
Seasoned Pro
Fixes: 12
Ah faulty router sound likely
picbits
I only ever manage to get around 30mb on my wireless connection (even though I've got a 300Mb/s router hooked up). If I use a dongle I get closer to my connection speed but my speed tests will always max out at around 28-32Mb on wireless.
If you try the wired connection on the router, don't forget to disable the onboard wireless on the laptop / computer as it may still be using that rather than the router LAN ports.
MW45
I have just done a few more tests both with ethernet cable and wirelessly, it is now even worse at just 6.74 Meg download 13.10 upload that is worse and I was getting with standard broadband. Please sort this out as soon as possible as I am paying for a service that is not been provided.
chrispurvey
I've arranged a router to be sent to you, this will be with you this week. There'll also be a returns bag for the faulty router.
MW45
I done what you said on the phone reset the router re-entered my login details, ethernet directly from laptop to plus net router now 66 Meg, but wireless is still only producing 33 Meg even though it is the latest N technology why is that?
