Not getting full bandwith
- Re: Not getting full bandwith
11-05-2018 12:12 PM
A few issues im trying to work through but i'll start with the main one. Using the Plusnet hub, wired only to one laptop for testing. I can see im syncing with the following.
Downstream Upstream Line Coding(Trellis): On On SNR Margin (1 dB): 6.4 6.0 Attenuation (1 dB): 5.0 4.5 Output Power (1 dBm): 0.0 12.6 Attainable Rate (Kbps): 23632 1232
I am very close to the exchange and over the last 8 years ive always managed to get 20M+ downloads. However with Plusnet I cant seem to get over ~17M.
Could anyone suggest what we can do with my profile/line config to get the maximum available bandwidth please.
Many thanks
Grant
11-05-2018 12:24 PM
Sorry to hear you're speeds aren't where you think they should be.
There's very little we can do as your profile is currently correct and your speeds are within the estimate we gave you.
As such we wouldn't be able to raise this as a fault.
11-05-2018 12:34 PM
You do appear to have interleaving applied to the downstream (96) - if your error rates are low the connection would run faster if it were removed.
11-05-2018 12:39 PM
Not sure what to do here then as with BT, SKY (as examples on the same line, exchange etc) I got the full bandwidth. Is there anything config wise we can change? As suggested by JayG can interleaving be removed please. Im so close to the exchange I can touch it. Am I being throttled in any other way perhaps? Is the profile high enough to allow full use of the bandwidth?
I hope we can get this sorted as Im so far impressed with Plusnet.
Regards
Grant
