Nortel Contivity Issues
- Re: Nortel Contivity Issues
12-11-2012 3:57 PM
If, like me, you have to use Nortel Contivity for VPN access, and you have a TG582n (currently running 8.C.M.0) then you will find that your access does not work.
Luckily (for you!) I have been through this pain before on O2 (when they upgraded my previous router firmware). To fix, you need to telnet to your router and input the following:
connection unbind application=IKE port=500-500
saveall
To undo (if this causes you other issues - which it shouldn't):
connection bind application=IKE port=500-500
saveall
This is due to a Technicolor firmware bug.
saveall
saveall
Message 1 of 4
(1,773 Views)
3 REPLIES 3
12-11-2012 4:03 PM
Message 2 of 4
(561 Views)
12-11-2012 8:39 PM
Thanks Conners, your piece of advice has saved us a lot of heart ache, my wife uses Nortel Contivity for work and she nearly went ballistic when she could not connect today after upgrading to fibre earlier a few hours earlier.
Thanks once again
From Two happy people
Thanks once again
Message 3 of 4
(561 Views)
13-11-2012 12:43 PM
Quote If, like me, you have to use Nortel Contivity for VPN access, and you have a TG582n (currently running 8.C.M.0) then you will find that your access does not work.
For information it's not just Nortel Contivity, any VPN using IPSec seems to have trouble with the TG582n and needs the 'connection unbind application=IKE' to work correctly.
http://community.plus.net/forum/index.php/topic,107399.0.html
http://community.plus.net/forum/index.php/topic,102798.0.html
Message 4 of 4
(561 Views)
