'Normal' evening SNRM drop/flat twisted pair RJ11 cable.
- 'Normal' evening SNRM drop/flat twisted pair RJ11 ...
Re: 'Normal' evening SNRM drop/flat twisted pair RJ11 cable.
28-11-2014 8:28 AM
Router log:
Thu, 2014-11-27 14:54:20 - Receive NTP Reply from time-g.netgear.com
Thu, 2014-11-27 14:56:04 - Administrator login successful - IP:192.168.0.2
Thu, 2014-11-27 15:50:20 - Router start up
Thu, 2014-11-27 15:15:35 - Initialize LCP.
Thu, 2014-11-27 15:15:35 - LCP is allowed to come up.
Thu, 2014-11-27 15:15:36 - CHAP authentication success
Thu, 2014-11-27 16:42:35 - Administrator login successful - IP:192.168.0.2
Thu, 2014-11-27 19:58:12 - Administrator login successful - IP:192.168.0.2
Thu, 2014-11-27 21:27:42 - Administrator login successful - IP:192.168.0.2
Thu, 2014-11-27 21:37:54 - Administrator login successful - IP:192.168.0.2
Fri, 2014-11-28 02:05:23 - UDP Packet - Source:89.163.239.65,5086 Destination:xx.xxx.109.218,5070 - [DOS]
Fri, 2014-11-28 02:05:24 - UDP Packet - Source:89.163.239.65,5086 Destination:xx.xxx.109.218,5071 - [DOS]
Fri, 2014-11-28 02:05:24 - UDP Packet - Source:89.163.239.65,5086 Destination:xx.xxx.109.218,5072 - [DOS]
Fri, 2014-11-28 02:05:24 - UDP Packet - Source:89.163.239.65,5086 Destination:xx.xxx.109.218,5073 - [DOS]
Fri, 2014-11-28 02:05:24 - UDP Packet - Source:89.163.239.65,5086 Destination:xx.xxx.109.218,5074 - [DOS]
Fri, 2014-11-28 02:05:24 - UDP Packet - Source:89.163.239.65 Destination:xx.xxx.109.218 - [PORT SCAN]
Fri, 2014-11-28 02:05:24 - Send E-mail Success!
Fri, 2014-11-28 08:03:26 - Administrator login successful - IP:192.168.0.2
Current DSL stats:
Downstream:
Noise Margin: 10.6 dB
Connection Rate: 8242 Kbps
Line Attenuation: 38.0 dB
Power: 0.0 dBm
Max Rate: 9220 Kbps
SuperFrames: 3856343
SF (CRC) Errors: 26
Reed Solomon: 501324594
RS Corrected: 80983
RS Un-Corrected: 274
HEC: 22
Errored Seconds: 18
Severe ES: 0
Interleave Depth: 64
Bitswaps: 18003
Upstream:
Noise Margin: 5.7 dB
Connection Rate: 1144 Kbps
Line Attenuation: 16.1 dB
Power: 12.4 dBm
Max Rate: 1148 Kbps
SuperFrames: 3476853
SF (CRC) Errors: 0
Reed Solomon: 3025812
RS Corrected: 0
RS Un-Corrected: 0
HEC: 0
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 4
Bitswaps: 361
Totals:
Total Uptimes (From SF counts):
WAN: 0 days, 18:15:47
LAN: 0 days, 18:15:47
CRC: 26
LOS: 0
LOF: 0
ES : 18
Bytes Transferred (ppp0):
Tx: 83182038 (79.3 MiB)
Rx: 2645128326 (2.4 GiB)
So, no drops, and only 26 CRC's reported - the higher than average (for me) Rx totals are because I downloaded 3 X 1 hour iplayer programmes at 1826, 1904, and 1924 (in HD) just to see what happened.
The graphs seem to show the odd hiccup though - will post some up in a new post when I've had another cup of coffee and a chance to look through them.
28-11-2014 8:59 AM
28-11-2014 9:27 AM
Edited to modify selection.
28-11-2014 9:39 AM
No wonder I got the error message
And now they are back
28-11-2014 9:42 AM
28-11-2014 9:42 AM
That 2306 event looks like what's called a "polling" issue, when the RS program can't get the data for whatever reason. More shortly.
28-11-2014 9:47 AM
28-11-2014 10:03 AM
Will post them all together for the sake of clarity, in two posts, starting with Rx SNRM:
28-11-2014 10:10 AM
28-11-2014 10:12 AM
28-11-2014 10:29 AM
28-11-2014 10:35 AM
28-11-2014 10:43 AM
28-11-2014 10:58 AM
Quote from: Anotherone It happens.
JayG,
RouterStats has an intermittent bug related to an internal message sequencing error. The symptoms are zero or bizarre plots. The cause is the "wrong" data being captured in the SUMMRY tab. Usually one can see the bits per tone data in there rather than the DSL stats.
The problem is readily "fixed" by clicking stop / start logging buttons.
I use the alarm "synch fallen below X" to alert me to the condition so that I can apply the fix.
I do not know if the issue is particularly associated with the tg582n or might be seen with any router. I've had it occur several times a day and never in a month.
Kevin
28-11-2014 11:02 AM
I can assure you that a correctly functioning TG582n (which has a Broadcom chipset btw, as does your Netgear) is more than capable of coping with some quite horrible lines, and yours, so far seems quite good. Post up later and I'll look back.
Quote from: Townman I reiterate my opinion again (this should not be a battle of opinions but a consideration of wisdom).
Sorry Kevin, your "opinion" is not a matter of fact, nor in this case, wisdom.
Quote from: Townman A straight line plot of increasing CRC simply shows that it is increasing, but not how it is increasing. Examination of the series of plots from a few posts back shows differing gradients from one graph to another, unless careful consideration is given to the changing scale of the axis, one could be fooled into assuming the rate of CRC generation was changing. It might be, but as the axis changes it is hard to tell.
I'm afraid you need to go back to school and do some revision of basic 'O' level/GCSE algebra and calculus.
A straight line graph shows precisely how something is increasing - it is increasing at a constant rate.
The rate of change in y with x ie. dy/dx is a constant for a straight line graph. (Also the gradient/slope of any graph at any point gives you the rate of change at that instant).
In this particular case, the actual rate isn't even relevant. The way & when it's doing it, in conjunction with the changed Target SNRM clearly indicates a fault. The history (ie prior to the 582n, see OP) suggests a stable connection, albeit with minor issues. This does suggest that the TG582n should be included in any consideration as to what is fault, going back to the Netgear currently indicates that inclusion was correct.
For your maths revision, here are some useful links
http://www.mathsisfun.com/gradient.html
http://www.mathsteacher.com.au/year10/ch03_linear_graphs/02_gradient/line.htm (note definition at the end of the page)
http://www.mathsrevision.net/advanced-level-maths-revision/pure-maths/calculus/differentiation-first...
Edit: definition remark was on wrong line!
