Noisy phone line repaired; how to restore broadband speed
markv
My SO, who I persuaded to switch to Plusnet, has had a noisy, buzzing phone line for ages. We finally reported it and a fault was acnowledged and today fixed by a man at a street cabinet.
Since the problem started, her broadband speed has dropped from ~ 10 Mb/s to ~ 2 Mb/sec.
Do we need to do anything to get that back up after the line repair?
8 REPLIES 8
JayG
Fixes: 6
Re: Noisy phone line repaired; how to restore broadband speed
Without seeing the current line stats from the router it's hard to tell if the line has been banded or otherwise 'adjusted' to try to cope with the line noise, but the odds are that it has.
Probably needs resetting by a member of the PlusNet staff who monitor these forums - hopefully they will pick this up for you and do whatever is required to restore normal performance.
Anoush
Aspiring Hero
Fixes: 139
Hi there @markv, if you private message me his Username I can check things out for you.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
markv
Many thanks. PM sent.
Anoush
Aspiring Hero
Fixes: 139
Thanks for your private message. I've tested their line and I'm still detecting a fault. I've passed the account to my colleague of our faults team now to contact Openreach to progress this along. I apologise for the inconvenience caused.
markv
Appreciate your help. Surprised there is still a problem showing. We had a VERY noticable buzz on the line and after the call from the OW engineer that completely dissapeared. Quiet Line Test now gives total silence.
My partner has received a call from Plusnet. Overall we're very impressed with the response we have recieved - thank you.
Mark
Anoush
Aspiring Hero
Fixes: 139
No problems, I'm happy to have helped.
It appears the problem we're still detecting may not be service affecting as my colleague explained to me that your partner advised things seem OK now. I think he sent the ticket back to her with a few checks to do if problems do occur.
Having said that, fingers crossed everything continues to work normally.
markv
The noise has certainly cleared. I will run speed tests at the first opportunity (Saturday).
Thanks again for you help.
Anoush
Aspiring Hero
Fixes: 139
Fantastic news, thanks for letting us know. Thumbs_Up
