Noise Margin
- Noise Margin
Re: Noise Margin
28-01-2013 12:08 PM
Re: Noise Margin
28-01-2013 12:09 PM
Re: Noise Margin
28-01-2013 12:11 PM
Re: Noise Margin
28-01-2013 12:18 PM
I suggest raising a speed fault at http://faults.plus.net
Re: Noise Margin
28-01-2013 3:21 PM
Many thanks for all your help
Re: Noise Margin
28-01-2013 3:25 PM
Re: Noise Margin
28-01-2013 3:41 PM
I still have to access the test socket, though, right?
Re: Noise Margin
28-01-2013 4:38 PM
Re: Noise Margin
28-01-2013 4:51 PM
Re: Noise Margin
28-01-2013 7:36 PM
Quote from: Anotherone Apart from the Master socket.do you have any other fixed extension sockets? Are you using any plug-in extension leads at all?
2x fixed extension sockets. One to the telephone upstairs, which is always connected, and one downstairs which the router was originally connected to but which is now temporarily unused. the router is now connected directly to the BT Master socket via a standard 5m telephone extension cable, since there is no power supply near the BT master socket itself. Both Sky boxes have been disconnected from the BT master socket and nothing else is connected apart from the router and telephone
Re: Noise Margin
28-01-2013 7:43 PM
If the only thing connected to that socket is the router put the filter next to the socket and use a twisted pair cat5e cable
Re: Noise Margin
28-01-2013 8:00 PM
Re: Noise Margin
28-01-2013 8:25 PM
When your Sky boxes were connected were they connected via filters? Do you all your Microfilters look like this?
Re: Noise Margin
28-01-2013 8:48 PM
Quote from: shure 2x fixed extension sockets. One to the telephone upstairs, which is always connected,
Is that phone plugged in via a filter?
Re: Noise Margin
28-01-2013 9:07 PM
I should say that things have improved greatly since I changed routers. I've had 98 hours so far without dropping connection once. Connection speeds are now also much better but for some reason in the evening (and sometimes -more rarely - during the day) I tend to gain jitter and my lag increases to some ungodly figure, along with my upload speed all but disappearing. The two things where issues are most noticeable are online gaming, where lag can be a pain in the a***, and Skype, where video can be almost impossible at times.
