Noise Margin
Re: Noise Margin
How long should i have to wait?  I was reading on a site about my bt2700hgv http://bt2700hgv.tripod.com/051.htm , that if my snr is set at 6db my router will sync at a slower speed , if i can get my snr lowered is there any way i can get it to not be set lower than 9db?
Re: Noise Margin
Is it possible for one of plusnet staff to reset my target snr?
Re: Noise Margin
Anyone? Wink
Re: Noise Margin
I can reset it for you, but this also resets the 10 day training period.
If you want it doing gimme the nod and I'll sort it now.
Re: Noise Margin
yes please mand, as long as it doesnt switch interleaving on !!  Thanks  Cheesy
Re: Noise Margin
When my target snr gets reset, should I reboot my router or will it sync (hopefully) higher on its own?
Legend
Fixes: 168
Re: Noise Margin
SNR reset requested, it shouldn't put interleaving on (if it does we can remove it next working day anyway).
You may find that the router resyncs when the noise margin changes anyway, otherwise one reboot a day mid-morning when the noise is lower would be best.
Re: Noise Margin
Thank you  Smiley
Re: Noise Margin
Amazing just checked and i have synced at 7040 !!  Cheesy Cheesy
Re: Noise Margin
............................now connected at 4960 Sad
Edit: What should i do now to try and get a stable sync?  It doesn't say on my routers stats that i have lost sync for days, but my sync has gone from 7040 today to 4960.  If i reboot my router tomorrow, will it have any adverse affects on my snrm  ?
Re: Noise Margin
have rebooted and synced at 6304, hopefully i can stay connected at that sync Smiley
Re: Noise Margin
nope lost sync again, now connected at 4416, have i got a line fault?  How would i go about researching this?
Fixes: 10
Re: Noise Margin
Can you post your current router stats please (sync speed, attenuation and noise margin)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Re: Noise Margin
DSL Line (Wire Pair): Line 1 (inner pair)
Protocol: G.DMT Annex A
Downstream Rate: 4416 kbps
Upstream Rate: 832 kbps
Channel: Fast
Current Noise Margin: 10.0 dB (Downstream) 11.0 dB (Upstream)
Current Attenuation: 41.7 dB (Downstream) 24.0 dB (Upstream)
Current Output Power: 19.7 dBm (Downstream) 12.3 dBm (Upstream)
Re: Noise Margin
can someone at plusnet tell me when i lost sync?  it was still 6304 when i checked at around 10am this morning , so it looks like i have lost sync at the time of day when signal should be at it's strongest?Huh
