Noise Margin
- Noise Margin
Re: Noise Margin
12-03-2010 7:50 AM
Re: Noise Margin
12-03-2010 4:38 PM
Re: Noise Margin
13-03-2010 8:23 PM
Re: Noise Margin
15-03-2010 5:29 PM
Re: Noise Margin
15-03-2010 5:59 PM
Re: Noise Margin
17-03-2010 9:43 PM
http://community.plus.net/forum/index.php/topic,81272.msg696507.html#new
Re: Noise Margin
19-03-2010 2:43 PM
Re: Noise Margin
31-03-2010 6:08 PM
Re: Noise Margin
05-04-2010 11:25 AM
Re: Noise Margin
06-04-2010 1:14 AM
Quote from: HaydnExport .... every time it rains in fact.....
If this is true, then you need a BT engineer to come round and sort all the connections on your drop wire.
For Plusnet to order this, you will need to re-raise the fault, and go through all the procedures to try and stabilise your line internally, including having interleaving turned on. If I were you, I'd live with this for the time being, until I could get the fault sorted out.
Best wishes
Chris
Re: Noise Margin
06-04-2010 10:07 AM
Re: Noise Margin
06-04-2010 11:10 AM
Its only really possible to give you an indication rather than a precise lead time here as there are a few factors at play such as waiting BT to respond and us then picking up on the queries and communicating with customers. We do normally advise that an initial response is given with in 72 hours and usually we can push a fault through to an awaiting appointment stage within that time. However I would urge you to bear in mind that things will take a little longer at present in terms of responses following the bank holiday weekend, but I would also urge you to get your fault raised via the fault checker at https://faults.plus.net without delay.
Re: Noise Margin
06-04-2010 2:55 PM
Re: Noise Margin
08-04-2010 7:16 PM
Re: Noise Margin
08-04-2010 10:22 PM
