Noise Margin
- Noise Margin
Re: Noise Margin
27-02-2010 6:12 PM
Re: Noise Margin
01-03-2010 6:41 PM
Re: Noise Margin
02-03-2010 5:14 PM
Re: Noise Margin
02-03-2010 6:42 PM
Re: Noise Margin
02-03-2010 6:51 PM
I know the feeling
Alastair
Re: Noise Margin
03-03-2010 1:41 PM
EDIT : Have asked you to take this fault to bt ID: 32307812 , just wondering if syncing at the max upload would have been causing the drops?
Re: Noise Margin
04-03-2010 9:14 AM
Re: Noise Margin
04-03-2010 11:13 AM
Re: Noise Margin
04-03-2010 11:16 AM
I'm looking at this ticket now for you, though as far as the fault resolution goes we'd be better leaving interleaving on until the fault's resolved. As soon as that's sorted we'll get it removed for you.
Re: Noise Margin
04-03-2010 11:28 AM
Re: Noise Margin
04-03-2010 11:32 AM
Re: Noise Margin
04-03-2010 11:35 AM
Re: Noise Margin
04-03-2010 12:00 PM
Re: Noise Margin
04-03-2010 12:28 PM
Re: Noise Margin
05-03-2010 8:00 AM
this is what bt speedtest says
FAQ
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
235 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 235 Kbps
For your connection, the acceptable range of speeds is 1200-7150 Kbps.
Additional Information:
Your DSL Connection Rate :5792 Kbps(DOWN-STREAM), 704 Kbps(UP-STREAM)
IP Profile for your line is - 5000 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit FAQ section if you are unable To understand the test results.
And my plusnet ip profile is 5000kb
Can someone kick something or get the magic wand out ?
