Noise Margin
- Re: Noise Margin
Re: Noise Margin
10-12-2009 12:41 PM
I have noticed the higher the noise margin the more stable my router stats seem, i have tried everthing i can think of to see if its my end thats the problem and cant find anything wrong no line noise etc etc etc, so im stumped.
Can my noise margin by set not to go below 9db?
Re: Noise Margin
10-12-2009 5:13 PM
0 days, 08:40:56
Upstream (Tx):
Good Cells: 295414
Idle Cells: 34430349
Downstream (Rx):
Good Cells: 2945150
Idle Cells: 626866943
Bad HEC Cells: 199230
Overflow Dropped: 0
Bytes Transferred (ppp0):
Tx: 10338992 (9.8 Mb)
Rx: 137353169 (130.9 Mb)
help!!
Re: Noise Margin
11-12-2009 3:24 AM
I'm not the Netgear expert, you'll have to wait for one but those errors do seem a touch high. Which is no real surprise if your Routerstats graph still looks like the last one you posted. Not only very spiky but that step as well. Any electrical apparatus nearby coming on or going off?
Re: Noise Margin
11-12-2009 1:06 PM
Borrowing a BT 2700HGV today, synced at 8096Kbps so cant be bad...
Re: Noise Margin
12-12-2009 9:20 AM
Re: Noise Margin
13-12-2009 2:40 PM
Thanks Anotherone & Jelv for your help
Re: Noise Margin
13-12-2009 9:01 PM
Re: Noise Margin
14-12-2009 11:29 AM
Re: Noise Margin
14-12-2009 7:09 PM
Uptime: 1 day, 4:55:44
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 832 / 4,224
Output Power (Up/Down) [dBm]: 12.5 / 19.5
Line Attenuation (Up/Down) [dB]: 24.0 / 42.0
SN Margin (Up/Down) [dB]: 7.0 / 11.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 5 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 3,982 / 1,452
HEC Errors (Up/Down): 1,824 / 875
Re: Noise Margin
14-12-2009 7:35 PM
If you want any help setting it up ( I had problems getting it working with routerstats) give us a shout..
Re: Noise Margin
14-12-2009 7:40 PM
Just thought id say i have had around 4.8mb in the past 3 months , but that was before i joined plusnet , funny thing is plusnets connection is miles better !!
Re: Noise Margin
16-12-2009 11:20 PM
Re: Noise Margin
17-12-2009 9:10 AM
Re: Noise Margin
17-12-2009 12:14 PM
Re: Noise Margin
17-12-2009 12:32 PM
