Noise Margin on new instalatiom
- Noise Margin on new instalatiom
24-04-2009 1:18 PM
24-04-2009 1:22 PM
Can you post the stats from your router - attenuation, speed, noise margin and errors
Re: Noise Margin on new instalatiom
24-04-2009 1:36 PM
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:434340 errors:0 dropped:0 overruns:0 frame:0
TX packets:308111 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:494274858 (471.3 Mb) TX bytes:59622693 (56.8 Mb)
ADSL Link Downstream Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 31 db 8 db
Noise Margin 10 db 28 db
24-04-2009 1:44 PM
Now when you go to ADSL2+ then your noise margin will drop and your speed will increase sigfnificantly
24-04-2009 1:58 PM
24-04-2009 2:28 PM
24-04-2009 3:04 PM
25-04-2009 3:17 PM
27-04-2009 11:07 AM
I'm using one of the err really cheap filters in my room (plugs straight in, no wires) whilst the front room (with phone) has the "mouse" type one, would changing my filter to a higher quality stop the noise marging from fluctuating or is that a natural thing?
27-04-2009 11:24 AM
Can you tie up the dips to any events (e.g. using the phone - incoming call)?
27-04-2009 12:22 PM
29-04-2009 4:59 PM
30-04-2009 12:57 PM
01-05-2009 11:45 PM
Edit: Having done some digging for your "other thread", can yoiu confirm that the blue is connected to 2, orange to 3, white to 5 on the master faceplate and all extension sockets? How many extension sockets are there and is "yours" the first in the chain?
Is the cable routed in a duct/conduit or is it buried in the wall?
