No, this is not good...Cannot connect to broadband.
- Re: No, this is not good...Cannot connect to broad...
- « Previous
- Next »
Re: No, this is not good...Cannot connect to broadband.
11-08-2010 5:30 PM
You'll be connecting on WPA anyway, not WPA2. You'll just be turning off a feature that's not currently in use. This should be the last or penultimate option on the same screen you were changing the wireless channel.
Message 31 of 37
(341 Views)
11-08-2010 5:46 PM
This one doesn't work, Ben. As soon as I clicked "apply" after changing WPA + WPA2 to WPA, the wireless connection on the netbook has cut off. My connection came back straight away after I changed everything back to what it was (WPA + WPA2).
Message 32 of 37
(341 Views)
11-08-2010 5:53 PM
Quote from: Ben You'll be connecting on WPA anyway, not WPA2. You'll just be turning off a feature that's not currently in use.
Ben can you explain why we should not be using wpa2 does plusnet not support this option?
As the OP said I too thought wpa2 was the best choice to stop others hijacking your wireless signal
I have a speedtouch 716wl which i brought direct from plusnet and have been using wpa2 on the understanding it was the best setting
Puddy
Message 33 of 37
(341 Views)
11-08-2010 5:58 PM
Quote from: Lolaan This one doesn't work, Ben. As soon as I clicked "apply" after changing WPA + WPA2 to WPA, the wireless connection on the netbook has cut off. My connection came back straight away after I changed everything back to what it was (WPA + WPA2).
If I do the same on my speedtouch I need to re- enter the routers password in all my wireless devices again and re-scan all wireless devices
Puddy
ps do the speedtouch plusnet branded router have their ssid and password on the label underneath the router like my speedtouch 716wl?. it saves having to make up a ssid and password
Message 34 of 37
(341 Views)
11-08-2010 6:09 PM
TG585 does come with a loose label and label underneath.
My WPA-PSK Version is WPA+WPA2
Message 35 of 37
(341 Views)
12-08-2010 10:12 AM
I had no drop in my connection since I've changed the channel yesterday.
I did notice that, on other websites, they seem to say that channels 1, 6 and 11 are the best to be on, as they don't overlap. Does that mean the other channels are to be avoided if possible?
Message 36 of 37
(341 Views)
12-08-2010 10:19 AM
The picture I previously posted shows how channels overlap. Channels 1 and 13 overlap with the fewest other channels so should be the clearest, assuming there are no other sources of noise present.
Neither WPA nor WPA2 are truely secure, any determined hacker would be able to break either. I must stress, however, that the chances of this happening are negligible for a residential network.
Message 37 of 37
(341 Views)
- « Previous
- Next »
