No response to ticket?
- No response to ticket?
17-12-2010 9:32 AM
Scuda
Re: No response to ticket?
17-12-2010 10:37 AM
17-12-2010 11:47 AM
17-12-2010 11:53 AM
Your profile has been matched to 4500 now so this should take effect shortly and you will see the increase in speed.
Jojo
17-12-2010 11:56 AM
dick:quote
17-12-2010 12:18 PM
Thank you for you time. If you can post back here when you have it set up I can run some tests again.
Jojo
17-12-2010 12:45 PM
Data Rate Down/up 1824/448
Noise Margin 12.5/15.0
Output Power 17.0/12.4
Attenuation 53.7/31.5
Note that this is the first time I have reset the router since reporting this last Tuesday
Hope that helps.
Scuda
17-12-2010 1:08 PM
As you can see the sync has increased by 500k just by doing that. I will now reset the SNR and see what happens.
Jojo
17-12-2010 1:18 PM
Scuda
17-12-2010 2:44 PM
Reset has taken effect. sync is now 2464 and profile 2000. I wouldn't necessarily say it's going to stay that way but I've matched the PN profile which should kick this into action within the next 15 mins.
Jojo
17-12-2010 3:35 PM
Scuda
17-12-2010 4:07 PM
I would leave it for a while to see if the line drops or the SNR increases before you consider any moves. The fact that the sync rate increased just by moving it to the test socket indicates there may be an issue with your extension.
Jojo
17-12-2010 4:16 PM
Scuda
26-12-2010 6:10 PM
It seems that there was an intermittent contact in the wiring to the extension socket. Having re-made the connections, using an IDC Tool, all now seems fine. The router has been in its normal position (not in the test position of the master socket, but in the extened socket) since 21 Dec, and is looking normal. Router stats today are:
Data Rate(Kbps)(Down__Up)____ 2112__448
Noise Margin___________________8.0__19.0
Output power__________________17.6__12.1
Attenuation____________________54.7__31.5
This is what has been normal for this line since Plusnet provided the service, so I have closed the ticket that my original post referred to.
Thanks for your help in doing the necessary checks at your end, and for your personal attention.
Hope your New Year is a good 'un!
Regards, scuda
27-12-2010 10:23 AM
Glad to hear you got it fixed.
Best wishes to you also.
Jojo
