No output power from exchange ?
- No output power from exchange ?
12-09-2011 10:21 AM
Type Fast Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 13999 1279
Noise Margin 5.6 7.2
Output power(dBm) 0.0 12.8
Attenuation(dB) 33 17
Why it showing output power for upstream but not on the downstream ? 0.0dBm as my router was still connection for 19 hours and 51 minutes without any drop
Re: No output power from exchange ?
12-09-2011 10:25 AM
12-09-2011 10:30 AM
12-09-2011 10:35 AM
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 12438 888
Noise Margin 4 12
Output power(dBm) 0 20
Attenuation(dB) 29 16
I hit refresh another 2 times and
Output power(dBm) 12 20
I don't think it is a problem, just maybe it is slow on the uptake every so often.
12-09-2011 11:18 AM
12-09-2011 11:24 AM
12-09-2011 3:21 PM
12-09-2011 4:36 PM
http://community.plus.net/forum/index.php/topic,98509.msg833777.html#msg833777
12-09-2011 4:44 PM
My mum line was 12000K, drop to 11000K, 10000K and now 9000K, mine was the same at 13000K, drop to 12000K, 10000K and probably drop to 9000K by tomorrow I reckon
12-09-2011 4:50 PM
12-09-2011 4:52 PM
12-09-2011 4:54 PM
Quote from: itsme Coax is nothing to do with BT.
Must be power box then (electricity) ? to the downstair toilet behind bin cupboard.
12-09-2011 4:58 PM
my very old wiring that is still in use, synch at 14000
coax for power - oh my god
12-09-2011 4:58 PM
12-09-2011 5:00 PM
Quote from: pierre_pierre coax for power - oh my god
I had the same thoughts.
