No nte5 master socket
- Re: No nte5 master socket
13-07-2013 1:10 AM
As title says, will this be a problem when engineer comes out to fit up the fibre socket? Forgot to add its the old 80s faceplate if that helps.
Message 1 of 4
(913 Views)
3 REPLIES 3
13-07-2013 2:19 AM
The engineer should fit a NTE5 for you.
Message 2 of 4
(412 Views)
16-07-2013 10:30 AM
Message 3 of 4
(412 Views)
16-07-2013 11:43 AM
Thank you both for your reply's.
Message 4 of 4
(412 Views)
