No connection since Wednesday
- Re: No connection since Wednesday
12-09-2008 3:05 PM
Trying to sort out my mum's plusnet broadband. There's no Internet connection. I've reset the router, re configured it, changed router, tried a different computer even.
I phoned plusnet and there is a fault in the Birmingham area - however this is leading to slow connections, not total service loss. Plus, the problem here pre-dates the current situation.
The guy on the phone said they cannot raise the error with BT while this area fault persists.
Can anyone suggest an alternative approach?
Message 1 of 2
(699 Views)
1 REPLY 1
12-09-2008 3:10 PM
The MSO in Birmingham has now been fixed so you should be able to get the fault raised.
Apologies for the delay.
Message 2 of 2
(258 Views)
