No connection........again
- No connection........again
24-05-2010 9:34 AM
I posted sometime ago regarding a problem with my mums broadband connection ( i referred her to plusnet).
Occasionally she would lose her connection to the internet (actually it wasn’t occasional, it was inevitable). Her connection could only be re-established if i reset the router to factory setting and re-inputted the plusnet connection details.
Last time I was there I switched the routers, she has my Thomson one (Plusnet's!) and i have her Belkin router (just to see if my connection would drop out). The same thing is happening now, she lost connection sometime on Saturday and cannot connect. Powering down and restarting does nothing!
This is obviously a problem with the line, but not something i have ever heard of, what ever is coming down the line is wiping the router settings (login etc) so i am unsure of what steps to follow, has anyone had the same sort of problem?
If i reset the router and run the fault diagnostics in the Plusnet member section surely it will tell me that i am connected and there are no problems, but it WILL break again sometime soon.
HELP PLEASE
Re: No connection........again
24-05-2010 9:49 AM
24-05-2010 9:49 AM
The username is ldickson, let me know what you find?
24-05-2010 10:51 AM
bt_test@startup_domain (no password, or password if the router won't accept that)
if that works:
bt_test_user@plusdsl.net (same password details as above).
Neither will actually offer a working connection however it counts as a success if the router shows it's connected.
If both of those work, try her own login details. If those work, then I'm not sure what's happening but if you report back with symptoms then I'll definitely be able to help further.
24-05-2010 11:05 AM
I dont know what symptoms i can tell you of, it just loses connection to the internet after X amount of time, on 2 different routers?
I will be going there after work and will try the test logins, obviously it isnt good enough that i have to reset her router every week or two, but i will get back to you this evening.tomorrow.
24-05-2010 6:26 PM
have started broadband checks, any help to speed this process along would be helpful!
24-05-2010 6:44 PM
See if the router syncs with the exchange and if so try to connect to PN with login details etc.
24-05-2010 8:53 PM
24-05-2010 10:07 PM
>>>>>>>>>>>>>>> http://www.kitz.co.uk/adsl/btsockets.htm
and the NTE5 etc.
>>>>>>>>>>>>>>> http://www.kitz.co.uk/adsl/socket.htm
24-05-2010 10:21 PM
24-05-2010 11:51 PM
Quote from: mrmarkus1981 There is no master socket,. its quite old!
The best thing to do in this case is to get the fault raised to BTw so that we can send an engineer out for you. However, I would like to test the line while the router is completely unplugged from the line. if the result are still showing in sync whilst the router unplugged then its jumpering fault at the exchange.
25-05-2010 9:32 AM
25-05-2010 9:41 AM
If the router is still unplugged, it's still showing as in sync, so as Rami suggests, it's probably a line card issue at the exchange if it (the router) hasn't been plugged back in again.
25-05-2010 9:52 AM
Thanks, that's something new I've learned
25-05-2010 10:30 AM
