No Phone or internet working
- No Phone or internet working
- « Previous
- 1
- 2
- Next »
Re: No Phone or internet working
14-02-2014 11:37 AM
Thanks for the information Michael.
I've escalated your Phone Fault Ticket from the Phone Faults Team to the broadband Faults Team for further investigation.
Message 16 of 22
(414 Views)
19-02-2014 1:25 PM
Hi Chris just an update,
BT engineer called out today and said he changed a few things around, He said before he was going that he tried to reset the SNR but said that you had one in progress so the internet will be slow and may take a few days (Friday) till you reset it on your side. He said when he closes the Job you should do it again.
Currently internet is 0.10mb - 0.21mb on the speedtest.
I wasn't sure if to post or not just incase you may double reset or something that might mess up things, but I really don't want to wait till Friday if not needed.
Thanks.
Thanks.
Message 17 of 22
(414 Views)
19-02-2014 1:53 PM
Thanks for the update.
I've just checked on our internal systems and I should be able to complete an SNR Reset tomorrow for you. The reset that was done previously expires at midnight tonight.
I'll get that done tomorrow for you.
Message 18 of 22
(414 Views)
20-02-2014 8:26 PM
No change in speed so far not sure if you did reset yet but still getting 0.1-0.2 download speed.
Message 19 of 22
(414 Views)
21-02-2014 10:18 AM
That's been sorted for you.
You might need to restart your router for the changes to take effect.
Message 20 of 22
(414 Views)
21-02-2014 1:55 PM
The router was reset 3hours 33mins ago it might have adjusted itself. Here's the router stats
xDSL Port Details Upstream Downstream
Line Rate: 0.480 Mbps 1.376 Mbps
Actual Net Data Rate: 0.448 Mbps 1.344 Mbps
Trellis Coding: ON ON
SNR Margin: 12.0 dB 8.1 dB
Actual Delay: 8 ms 8 ms
Transmit Power: 12.5 dBm 16.7 dBm
Receive Power: 4.7 dBm 4.7 dBm
Actual INP: 1.5 symbols 1.0 symbols
Total Attenuation: 0.0 dB 0.0 dB
Attainable Net Data Rate: 0.812 Mbps 2.024 Mbps
Speed is still slow test says 0.47mb upload and 0.36mb upload. Do you think it will rise?
Message 21 of 22
(414 Views)
24-02-2014 12:18 PM
Have your speeds picked up yet?
If they haven't, I would reply back to Ticket: 81017793 and our Faults Team will be able to investigate further for you.
Message 22 of 22
(414 Views)
- « Previous
- 1
- 2
- Next »
