No Internet :(
- No Internet :(
Re: No Internet :(
17-04-2009 10:10 AM
Line is in sync as it always has been but no internet
Quote /usr/sbin/adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 1
Channel: INTR, Upstream rate = 736 Kbps, Downstream rate = 3936 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Interleave
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 12.6 11.0
Attn(dB): 51.0 31.5
Pwr(dBm): 19.2 12.4
Max(Kbps): 4480 992
Rate (Kbps): 3936 736
G.dmt framing
K: 124(0) 24
R: 16 16
S: 1 4
😧 16 4
ADSL2 framing
MSGc: 1 1
B: 125 24
M: 1 4
T: 1 1
R: 16 16
S: 1.1269 4.6400
L: 1008 200
😧 16 4
Counters
SF: 106789 106730
SFErr: 3 0
RS: 7261698 1814410
RSCorr: 1308 0
RSUnCorr: 12 0
HEC: 3 0
OCD: 0 0
LCD: 0 0
Total Cells: 16852809 0
Data Cells: 217 0
Drop Cells: 0
Bit Errors: 0 0
ES: 80 0
SES: 3 0
UAS: 167 0
AS: 1815
INP: 1.01 1.28
PER: 1.97 2.03
delay: 4.50 4.64
OR: 28.39 27.58
Bitswap: 0 0
Total time = 15 hours 8 min 24 sec
SF = 3192841
CRC = 678
LOS = 2
LOF = 11
ES = 80
Latest 1 day time = 15 hours 8 min 24 sec
SF = 3192841
CRC = 678
LOS = 2
LOF = 11
ES = 80
Latest 15 minutes time = 8 min 24 sec
SF = 29677
CRC = 2
LOS = 0
LOF = 0
ES = 2
Previous 15 minutes time = 15 min 0 sec
SF = 52923
CRC = 1
LOS = 0
LOF = 0
ES = 1
Previous 1 day time = 0 sec
SF = 0
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 46314
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
Showtime Drop Reason: 1
Last Retrain Reason: 1
Re: No Internet :(
17-04-2009 10:17 AM
Re: No Internet :(
17-04-2009 10:35 AM
Re: No Internet :(
17-04-2009 11:00 AM
We need to get the engineer out so he can test the line from your premises as this should give more information on top of the exchange tests.
As regards the router, is it flashed and up to date with the latest firmware? Version 1.02.16 is at http://kb.netgear.com/app/answers/detail/a_id/932 if you need it (sorry if you're already there).
Could you try factory resetting the netgear, reflashing with the latest firmware and then running back through the setup? I know it's a pain but we've seen some issues with netgear kit in the past that was sorted by doing the above.
Re: No Internet :(
17-04-2009 11:04 AM
Re: No Internet :(
17-04-2009 11:12 AM
Re: No Internet :(
17-04-2009 11:18 AM
Re: No Internet :(
17-04-2009 11:22 AM
The BT test showed this
Quote 16/04/2009 13:01:39
BT Wholesale / Chester- Fault has been reported as no connection. Circuit is currently testing not in sync. Circuit history is not showing any recent working sessions. Line test is passing ok with a line length of 3.6km. Radius BBVR also matches system records for the circuit.
Circuit is testing jumpered all ok in the exchange. The Tam wideband test however is showing poor carrier frequencies.
Passing case to CP to check the EU equipment and setup and to book an engineering appointment to investigate fault further
If at the time of testing the OP modem was in sync with the exchange I would suggest the BT system was looking at a different ADSL circuit.
Re: No Internet :(
17-04-2009 11:28 AM
Quote [Internal]
xSDl status check conducted on service $2 BBEU00044900
Test OutCome Pass
Circuit Sync Status Circuit Out of Sync
Mux Port Status N/A
Upstream Link Info
Loop Loss 0
Loop Loss Add Text N/A
SNR Margin 0
Errored Seconds 0
HecErrors 0
Cell Count 0
Speed 0
Downstream Link Info
Loop Loss 0
SNR Margin 0
Errored Seconds 0
HecErrors N/A
Cell Count 0
Speed 0
DSL Max Data
BIP Interface Data
Current line rate
Line rate change timestamp 01/01/1111 01:00:00
Maximum Stable Rate Recalcuated N
ProfileTimestamp 01/01/1111 01:00:00
Maximum Stable Rate 2272
Fault Threshold Rate 2272
Interleaving Flag
NTE Detail
Equipment Status N/A
Power Status NTE
BypassStatus N/A
Outcome Summary
Test OutCome Pass
Description Line status not in sync
Re: No Internet :(
17-04-2009 1:43 PM
Re: No Internet :(
17-04-2009 1:54 PM
Re: No Internet :(
17-04-2009 3:19 PM
Also this may be a long shot but would they have wired me up on the wrong jumpers as in the upload speed i sync at seems very familular (sky 768 upload) . Sky was the ISP before PN .
Re: No Internet :(
18-04-2009 10:23 AM
Re: No Internet :(
18-04-2009 10:56 AM
Mark
Re: No Internet :(
18-04-2009 11:05 AM
Quote ...............
To me, something else that suggests a mis-configuration.
