No Broadband
- No Broadband
No Broadband
07-12-2020 10:02 PM
I disconnected my ADSL filter in order to test another filter, I then couldn’t connect to the internet,? I swapped the filter back so the cables were exactly as before and still no internet, I despair at what can be wrong, anyone????
Message 1 of 3
(508 Views)
2 REPLIES 2
Re: No Broadband
07-12-2020 10:38 PM
Mine has been off since around 4 30pm . Apparently there's a fault when we called, although its not showing on any service issues online. Customer service closed until tomorrow, I'm sure they will be getting plenty of calls first thing.
Message 2 of 3
(500 Views)
Re: No Broadband
08-12-2020 8:25 AM
@DylanFan3 How far can you get towards a connection before it fails - i.e. what lights are on your router and what are they doing?
@Crazycat Your issue is totally different, and you should have started your own topic - high-jacking someone else's is bad practice and makes it difficult for anyone to help.
Message 3 of 3
(468 Views)
